LeeJaeYoung
How to get the depth of a groove in a curtain wall?
I am studying cw window 26.
The left side is cw window 26.
I am not understanding how to get the groove depth value.
Which part should I study?
ADD2 0,0.1
POLY2 4,7,
 0,-FrameThk/2,
 A,-FrameThk/2,
 A,FrameThk/2,
 0,FrameThk/2
1.  It seems to me that this A has an ac_clampdepth value.
    There is an ac_clampdepth value in frames, but it's hard to understand how to get that value in windows because it's so complicated.
    I want to know how to get ac_clampdepth value.
2. It's too complicated, so I just set the center of the window to ADD2 A/2,0 in the 2D script, but is there any problem doing this?
ADD2 0,0.1
add2 A / 2, 0
HA = windowWidth /2
POLY2 4,7,
   -HA,-FrameThk/2,
    HA,-FrameThk/2,
    HA, FrameThk/2,
   -HA, FrameThk/2
AC27 on window 11
4 Replies 4
LeeJaeYoung
I found this.
I couldn't find the variable in CW window 26 when I searched for it in ui_CWWindow_m.
I want to know the variable values of these pens.
The clues I've found are here.
! Additional independent pages
_idxTab = 300
iUiID_FloorPlanSection = _idxTab
iParID_FloorPlanSection = iUiID_Root : _idxTab = _idxTab + 1
AC27 on window 11
Peter Baksa
Generally these names are the same as the parameter's description. You can search for it in the GDL editor parameter list, or browse them in Schedules / Scheme settings / Fields / Add Fields / Library Part Parameters:
Péter Baksa
Software Engineer, Library
Graphisoft SE, Budapest
LeeJaeYoung
thanks for the answer ^^
The question you answered is what I found below. ^^
I want you, the expert, to answer my questions 1 and 2. ^^
AC27 on window 11
Peter Baksa
https://gdl.graphisoft.com/gdl_other_docs/how-to-make-a-curtain-wall-panel discusses clamp sizes and panel coordinates.
Parameter A depends on ac_aSizeIsWithClamp, you need to set it to use the simplification.
Péter Baksa
