SimonWeinberger
How to react to AddOnObject changes?
If I understand it correctly, the benefit of ACAPI_​AddOnObject_* methods over ACAPI_ModulData_* is that you can a) perform changes inside an undo scope and b) sync the data to the server (and other people). But how can I react to this happening?
I'd like to know when there are changes to AddOnObjects due to undo/redo or sync with server, but I couldn't find any events handling this. What are the methods I need to use for this? e.g. ACAPI_Element_AttachObserver does not work, AddOnObjects are no real objects despite being addressed via GUID.
8 Replies 8
Tamas Polyak
Please check here: Archicad 29 C++ API: Add-On Objects
It states the requirements for the notifications to work. Please report it if it still doesn't work.
Best regards,
Tamás
SimonWeinberger
The methods you mentioned do work, but they don't cover the scenario I'm interested in. The user performing undo/redo does not call the installed handlers, only load/save of an older archicad file format does so.
Tamas Polyak
Please clarify, is it with Undo/Redo that you don't get notifications. Do notifications for create and delete elements work?
Best regards,
Tamás
SimonWeinberger
I want to get notified whenever the user performs undo/redo that includes an added/deleted/changed AddOnObject, and I can't find an API for that.
ACAPI_Element_AttachObserver does not work with GUIDs from AddOnObjects.
ACAPI_AddOnObject_RegisterAddOnObjectHandler/ACAPI_AddOnObject_InstallAddOnObject...Handler does not trigger for undo/redo.
Tamas Polyak
I can only think of a workaround for this. Perhaps you should maintain a table in the addon that connects element guids to addOnObject guids.
On opening/joining a plan go through all the elements, build a table, then maintain it by notifications on create/delete/undo/redo.
Your addon should be resident for this, so it's not unloaded after use.
Regards,
Tamás
SimonWeinberger
Sorry, but this workaround doesn't help me at all. If it made sense to attach data to elements I wouldn't need AddOnObjects in the first place and could use other means of storing data, e.g. ACAPI_Element_SetUserData. I use ACAPI_ModulData_* (or ACAPI_AddOnObjects_*) to store data that is not connected to any elements.
Tamas Polyak
As I understood, the AddOn needs to maintain a table or database that can be updated according to the user's actions, adding, changing, deleting.
Regards,
Tamás
SimonWeinberger
Exactly, I need notifications for added/changed/deleted AddOnObjects to maintain the data, and I can't find these notifications. I know the changes that my code is doing itself, but the user can perform undo/redo, and there is no way of me knowing when this happens.
The alternative is polling, e.g. read all AddOnObjects every 10 milliseconds, but I don't really like this approach because it might be a performance problem with many and/or large AddOnObjects.
