YONGWOO KIM
How to remove custom faces in morph?
I want to change morph's material(surface).
I change material property in morph, but it's not work.
After morph is created, I check property in archicad.
It says 'Apply changes to custom faces/edges too'. (In picture)
This is occur when I did solid operation.
In memo, there is 'morphMaterialMapTable'.
I change that to false. And change material again. But, It's not work too.
I can not find parameter about custom face.
How can I change turn off or remove custom faces in code?
0 Replies 0
