Archicad C++ API
How to use ChangeDefaultsExt to MyDoor Object
I would like to ChangeDefaults Door and Window(Change Object).
Ex.
- I have 2 door object [MyDoor1.gsm , MyDoor2.gsm].
- And "MyDoor1" is Defaults object then i would like change to "MyDoor2" object.
5 REPLIES 5
Ex.
Traro,
If i understand you question properly, you can alt-click on an existing object in the floorplan to make that the default object when a new instance is placed.
Ex.
I suggest first getting the object defaults with ACAPI_Element_GetDefaults. The critical information required for setting the correct library part is the libInd value in the API_ObjectType structure. This is a temporary index to the object in the loaded libraries. You can find this using ACAPI_LibPart_Search with the name of the target object.
I can't recollect whether it's essential to get the default parameters for this object to set in the tool defaults, but you can get this information using ACAPI_LibPart_GetParams (parameters and default size).
Ralph Wessel BArch
Central Innovation
Tamas Zolnai
Ralph wrote:
Ex.
I absolutely agree with Ralph Wessel using these methods to change the default object. I wrote a code sample based on these methods,
which changes the default door object to "Door with Sidelight on Side 1 19". I hope it will be helpfull:
	API_LibPart			libDoor;
	API_Element			elementDoor;
	API_ElementMemo		memo;
	GSErrCode			err = NoError;
	// Get defaults for door element
	BNZeroMemory (&elementDoor, sizeof (API_Element));
	elementDoor.header.typeID = API_DoorID;
	err = ACAPI_Element_GetDefaults (&elementDoor, &memo);
	if (err != NoError) {
		WriteReport_Alert ("Cannot get door defaults");
		return;
	// Get a door object from library using its name
	BNZeroMemory (&libDoor, sizeof (libDoor));
	const GS::UniString uName ("Door with Sidelight on Side 1 19");
	GS::ucscpy (libDoor.docu_UName, uName.ToUStr ());
	err = ACAPI_LibPart_Search (&libDoor, false);
		WriteReport_Alert ("No libpart found with that name");
		return;
	delete libDoor.location; // don't forget to free location
	// Change libInd of the default door to the new one
		API_Element mask;
		ACAPI_ELEMENT_MASK_CLEAR (mask);
		ACAPI_ELEMENT_MASK_SET (mask, API_DoorType, openingBase.libInd);
		elementDoor.door.openingBase.libInd = libDoor.index;
		err = ACAPI_Element_ChangeDefaults (&elementDoor, &memo, &mask);
			WriteReport_Alert ("Cannot change door defaults");
			return;
	// Check whether defaults were updated
		API_Element elementDoor2;
		elementDoor2.header.typeID = API_DoorID;
		err = ACAPI_Element_GetDefaults (&elementDoor2, NULL);
			return;
		if (elementDoor2.door.openingBase.libInd != libDoor.index) {
			WriteReport_Alert ("Door default settings were not updated");
			return;
This example changes only the default door object nothing more (e.g. not using default parameters of this door object).
Traro,
Is this what you searching for?
Tamás Zolnai
Thanks to everyone
Tamas Zolnai
To load also the default parameters (e.g. marker) of the door object from library,
amend the code as the following lines shows ('+' means additions):
    API_Element mask;
+  // Set default params of the new door object
+     double a, b;
+     Int32 addParNum;
+     API_AddParType  **addPars;
+     err = ACAPI_LibPart_GetParams (libDoor.index, &a, &b, &addParNum, &addPars);
+     if (err) {
+        WriteReport_Alert ("Cannot get libpart params");
+        return;
+     memo.params = addPars;
       return;
+   ACAPI_DisposeElemMemoHdls (&memo);
Tamás Zolnai
