How to use ChangeDefaultsExt to MyDoor Object
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
2015-03-05
03:01 PM
2023-08-01
01:34 PM
Doreena Deng
2015-03-05
03:01 PM
I would like to ChangeDefaults Door and Window(Change Object).
Ex.
- I have 2 door object [MyDoor1.gsm , MyDoor2.gsm].
- And "MyDoor1" is Defaults object then i would like change to "MyDoor2" object.
Ex.
Labels:
- Labels:
Add-On (C++)
5 REPLIES 5
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2015-03-06 12:23 AM
2015-03-06
12:23 AM
Traro wrote:Traro,
Ex.
If i understand you question properly, you can alt-click on an existing object in the floorplan to make that the default object when a new instance is placed.
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2015-03-06 12:00 PM
2015-03-06
12:00 PM
Traro wrote:I suggest first getting the object defaults with
Ex.
I can't recollect whether it's essential to get the default parameters for this object to set in the tool defaults, but you can get this information using
Ralph Wessel BArch
Central Innovation
Central Innovation
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2015-03-06 04:10 PM
2015-03-06
04:10 PM
Ralph wrote:I absolutely agree with Ralph Wessel using these methods to change the default object. I wrote a code sample based on these methods,Traro wrote:I suggest first getting the object defaults with
Ex.
- And "MyDoor1" is Defaults object then i would like change to "MyDoor2" object.ACAPI_Element_GetDefaults. The critical information required for setting the correct library part is the libIndvalue in the API_ObjectTypestructure. This is a temporary index to the object in the loaded libraries. You can find this using ACAPI_LibPart_Searchwith the name of the target object.
I can't recollect whether it's essential to get the default parameters for this object to set in the tool defaults, but you can get this information usingACAPI_LibPart_GetParams(parameters and default size).
which changes the default door object to "Door with Sidelight on Side 1 19". I hope it will be helpfull:
API_LibPart libDoor;
API_Element elementDoor;
API_ElementMemo memo;
GSErrCode err = NoError;
// Get defaults for door element
BNZeroMemory (&elementDoor, sizeof (API_Element));
elementDoor.header.typeID = API_DoorID;
err = ACAPI_Element_GetDefaults (&elementDoor, &memo);
if (err != NoError) {
WriteReport_Alert ("Cannot get door defaults");
return;
// Get a door object from library using its name
BNZeroMemory (&libDoor, sizeof (libDoor));
const GS::UniString uName ("Door with Sidelight on Side 1 19");
GS::ucscpy (libDoor.docu_UName, uName.ToUStr ());
err = ACAPI_LibPart_Search (&libDoor, false);
WriteReport_Alert ("No libpart found with that name");
return;
delete libDoor.location; // don't forget to free location
// Change libInd of the default door to the new one
API_Element mask;
ACAPI_ELEMENT_MASK_CLEAR (mask);
ACAPI_ELEMENT_MASK_SET (mask, API_DoorType, openingBase.libInd);
elementDoor.door.openingBase.libInd = libDoor.index;
err = ACAPI_Element_ChangeDefaults (&elementDoor, &memo, &mask);
WriteReport_Alert ("Cannot change door defaults");
return;
// Check whether defaults were updated
API_Element elementDoor2;
elementDoor2.header.typeID = API_DoorID;
err = ACAPI_Element_GetDefaults (&elementDoor2, NULL);
return;
if (elementDoor2.door.openingBase.libInd != libDoor.index) {
WriteReport_Alert ("Door default settings were not updated");
return;
This example changes only the default door object nothing more (e.g. not using default parameters of this door object).Traro,
Is this what you searching for?
Tamás Zolnai
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2015-03-11 09:31 AM
2015-03-11
09:31 AM
Thanks to everyone
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2015-03-13 02:58 PM
2015-03-13
02:58 PM
To load also the default parameters (e.g. marker) of the door object from library,
amend the code as the following lines shows ('+' means additions):
API_Element mask;
+ // Set default params of the new door object
+ double a, b;
+ Int32 addParNum;
+ API_AddParType **addPars;
+ err = ACAPI_LibPart_GetParams (libDoor.index, &a, &b, &addParNum, &addPars);
+ if (err) {
+ WriteReport_Alert ("Cannot get libpart params");
+ return;
+ memo.params = addPars;
return;
+ ACAPI_DisposeElemMemoHdls (&memo);
Tamás Zolnai
