Archicad C++ API
How to use ModalDialog ????
i'm trying to use modalDialog class so as to have a window with a textEdit, a label and two button( cancel and ok).
I tried this :
- In GRC file :
'GDLG'  4000  Modal   100  100  100  100  "Test Window" {
TextEdit   20  20  60  20  SmallPlain   255
- In cpp file :
DG::ModalDialog* modalWindow = new DG::ModalDialog(4000);
if(!modalWindow->Invoke())
    ACAPI_WriteReport("Invoke failed",true);
But the invoke always failed.
May be my grc file is not correctly written, i don't know.
If somebody already used Modaldialog and could help me, i would thank him a lot.
Thank you.
Sébastien
10 REPLIES 10
Ralph Wessel
Mentor
Your resource IDs should start from 32500 (except for palettes and modeless dialogs, which start from 32400).
Ralph Wessel BArch
Active Thread Ltd
I changed my ressourceId to 32520 but the invoke failed again.
Is it better to use this fonction :
DG::ModalDialog* modalWindow = new DG::ModalDialog(32520);
modalWindow->Invoke();
or this fonction :
DGModalDialog (Fill_GDLGID, Fill_Handler, (DGUserData) &prefsData)
like in the exemple ???
Thank you
Ralph Wessel
Mentor
ModalDialog
or this fonction :
DGModalDialog
Check that your resources compiled with the new ID too.
I use DGModalDialog for several reasons:
  • - All the DG functions have better documentation;
    - It works across more versions of ArchiCAD;
    - I have my own dialog class anyway (wrapping the DG functions) so I can write:
    Dialog about(aboutResID);
    about.show();
Ralph Wessel BArch
Active Thread Ltd
I suppose you would not want to give me your class ?
Or may be a simple exemple of using which make me able to get back data from textedit.
Thank you
I succeeded to create a modalDialog with two buttons ok and cancel and with a textedit with the DGModalDialog.
But I can't write into my textedit, do you know where could be the problem?
'GDLG'  32500    Modal    0    0  420  460  "Window test"  {
/* [  1] */ Button             340  425   70   20  LargePlain     "OK"
/* [  2] */ Button             260  425   70   20  LargePlain     "Cancel"
/* [  3] */ TextEdit			8    4  250   20  SmallPlain		30
static short DGCALLBACK myWindow_Handler (short				message,
									  short				dialogID,
									  short				item,
									  DGUserData		userData,
									  DGMessageData		msgData)
	msgData = msgData;
	userData = userData;
	item = item;
	dialogID = dialogID;
	switch (message)
		case DG_MSG_INIT:
			break;
		case DG_MSG_CLICK:
			if(item == 1)
				ACAPI_WriteReport("OK",true);
			break;
		case DG_MSG_CLOSE:
			break;
	return 1;
}		// Fill_Handler
static void Do_myWindow (void)
	GSResModule 	filNum;
	// Get the dialog from our resource file
	filNum = ACAPI_UseOwnResModule ();
	DGModalDialog (32500, myWindow_Handler,0);
	ACAPI_ResetResModule (filNum);
}		// Do_FillSettings
Thanks
hello, It's me again,
I found how to et retrieve text data from the textEdit (DGGetItemText for them who are looking for it), but I do not succeed to write into this one since my keyboard, i only can fill it by Copy/Paste.
If somebody knows why I can't write with my keyboard in my TextEdit , Thank you in advance
::::::::::::::::::::::EDIT ::::::::::::::::::::::
I found the solution,
in the callback function I had to add this in the switch(message) :
case DG_MSG_FILTERCHAR:
				 test[0] = char(msgData);
				 test[1] = '\0';
				 strcat(contentKeyValidation,test);
				DGSetItemText (32509, 2, contentKeyValidation);
			break;
:::::::::::::::::::END EDIT :::::::::::::::::::
Oleg
Hi Atila,
Currently I use DG:: classes and I dont remember about this callback exactly, so guessing.
I think you need to try "return 0;" instead "return 1" in your exampe.
I dont think you need handle FILTERCHAR at all.
Except DialogManager documentation you can look in DG_Test example.
Oleg.
you're right, the "return 0 is a mistake, but I do not find how to write in the editbox, the FILTERCHAR is the only way i found to enter any text.
All caracters seems to be filtered.
Oleg
Hmm, may be I am wrong,
but I think "return 1" was the reason why EditBox didnt work, as it mean all chars were filtered out.
Are you tried "return 0" and remove FILTERCHAR handler ?
If it dont work, then I dont know what is a reason.
Oleg
