‎2009-02-09
10:44 AM
‎2023-08-03
05:24 PM
Doreena Deng
'GDLG' 4000 Modal 100 100 100 100 "Test Window" {
TextEdit 20 20 60 20 SmallPlain 255
- In cpp file :DG::ModalDialog* modalWindow = new DG::ModalDialog(4000);
if(!modalWindow->Invoke())
ACAPI_WriteReport("Invoke failed",true);
But the invoke always failed.‎2009-02-09 01:20 PM
atila-diffusion wrote:Your resource IDs should start from 32500 (except for palettes and modeless dialogs, which start from 32400).
i'm trying to use modalDialog class so as to have a window with a textEdit, a label and two button( cancel and ok).
May be my grc file is not correctly written, i don't know.
‎2009-02-09 02:08 PM
DG::ModalDialog* modalWindow = new DG::ModalDialog(32520); modalWindow->Invoke();
DGModalDialog (Fill_GDLGID, Fill_Handler, (DGUserData) &prefsData)like in the exemple ???
‎2009-02-09 02:41 PM
atila-diffusion wrote:Check that your resources compiled with the new ID too.
I changed my ressourceId to 32520 but the invoke failed again.
Is it better to use this fonction :
ModalDialog
or this fonction :
DGModalDialog
Dialog about(aboutResID); about.show();
‎2009-02-09 02:52 PM
‎2009-02-10 03:33 PM
'GDLG' 32500 Modal 0 0 420 460 "Window test" {
/* [ 1] */ Button 340 425 70 20 LargePlain "OK"
/* [ 2] */ Button 260 425 70 20 LargePlain "Cancel"
/* [ 3] */ TextEdit 8 4 250 20 SmallPlain 30
static short DGCALLBACK myWindow_Handler (short message,
short dialogID,
short item,
DGUserData userData,
DGMessageData msgData)
msgData = msgData;
userData = userData;
item = item;
dialogID = dialogID;
switch (message)
case DG_MSG_INIT:
break;
case DG_MSG_CLICK:
if(item == 1)
ACAPI_WriteReport("OK",true);
break;
case DG_MSG_CLOSE:
break;
return 1;
} // Fill_Handler
static void Do_myWindow (void)
GSResModule filNum;
// Get the dialog from our resource file
filNum = ACAPI_UseOwnResModule ();
DGModalDialog (32500, myWindow_Handler,0);
ACAPI_ResetResModule (filNum);
} // Do_FillSettings
Thanks
‎2009-02-16 11:11 AM
case DG_MSG_FILTERCHAR: test[0] = char(msgData); test[1] = '\0'; strcat(contentKeyValidation,test); DGSetItemText (32509, 2, contentKeyValidation); break;:::::::::::::::::::END EDIT :::::::::::::::::::
‎2009-02-17 03:27 PM
‎2009-02-17 09:11 PM
‎2009-02-18 06:05 AM
