‎2022-04-19 07:56 PM
ACAPI_ELEMENT_MASK_CLEAR(mask);
ACAPI_ELEMENT_MASK_SET(mask, API_LabelType, parent);
element.label.parent = guid;
err = ACAPI_Element_Change(&element, &mask, &memo, 0, true);
This code is wrong.
The label is not associated with a new element.
Solved! Go to Solution.
‎2022-04-20 04:54 AM
I believe that once created and placed, the status of a label can not be changed. This is because associated labels acquire the guid of the element they are attached to. Maybe wrong on this one?
‎2022-04-20 01:45 PM
This is the part I don't understand.
If it's because of the Guid, it's because you'll have to re-specify the Guid.
If I need to fetch information via Guid, but there is no command to get it back, then I can understand.
This article was translated from translate.google.com.
‎2022-04-25 05:40 AM
I know what you said is true.
thank you.
Have a nice day
API_LabelType
parent
When creating new Labels,
set this to APINULLGuid to create an independent Label; or
set this to the GUID of the owner element (a labelable element) to create an associative Label.
When getting or changing a Label, this member will be filled with the GUID of the owner element,
or APINULLGuid, if the Label is independent.
It is not allowed to make an existing associative Label independent,
or make an existing independent Label associative.
