Archicad C++ API
Is there a way to convert a dwg file to an xyz file?
YONGWOO KIM
I want to convert dwg file to xyz file.
Is there any solutions?
It doesn't have to be ArchiCAD API.
Guru
https://community.graphisoft.com/t5/Modeling/From-DWG-to-MESH-a-trick/td-p/167434
There are also converters around online, though I have never used any of them
1 REPLY 1
Guru
