Archicad C++ API
Is there a way to create a GDL custom label with projected elevation dimension in floor plan
I can't find any global variable or request for the elevation dimension like the one is in the dimension tool so i can get the level of the projected point of associated object in the floor plan with a custom label.
e.g. for getting the level of different points of a sloped roof, mesh, morph or shell in a floor plan or 3d document projected site view.
Regards.
1 REPLY 1
DGSketcher
Legend
Levels on plan are created with a dedicated Level Dimension tool.
You will find more here... https://helpcenter.graphisoft.com/user-guide/89086/
