Archein
Is there any api function to modify morphs?
Hello everyone,
I'm trying to union morphs and merge faces to get the boundary,
which is more intuitive than convex hull and concave hull, I think.
But I can't find which api function is possible to achieve this.
Otherwise, I'll write a merge function.
Any advice would be appreciated.
1 Solution
Hiromichi Shinkawa
I'm afriad you cannot find API function for morph same as 'Smooth & Merge Faces'... but if you'd unify polygons maybe you can use api Geometry::UnifyPolygon2DData() function.
HTH.
Go to post
Hiromichi Shinkawa
HTH.
Archein
Thanks,I'll give it a try.👍
