‎2010-05-19
09:50 AM
‎2023-08-03
11:48 AM
Doreena Deng
HRESULT hr = CoInitialize(NULL);
try
MyInterop::IMyDotNetInterfacePtr pdata(__uuidof(MyInterop::MyDotNetClass));
catch(_com_error err)
CoUninitialize();
When I Execute that code, then close the AC13, it crashed in mep.dll.
//================= BEGIN REPORT ======================
Exception (process terminated)
NetBIOS name:
User name : *
Account name: *
Domain name : *
Program Version: 13.0.0 R1 (3259)
Package Version: Kheops FULL CHI 3259
Command Line: <"C:\Program Files\Graphisoft\ArchiCAD 13\ArchiCAD.exe" >
Process ID : 4112
Thread ID : 3244
WibuData: DemoMode
ProjectName: *
OS Version : Windows NT 5.1.2600 (32-bit) Service Pack 3
Session start: 2010/05/19 07:37:50
System time: 2010/05/19 07:39:57
MS VC minidump file created at: C:\Documents and Settings\*\Graphisoft\BugReporting-13\CrashDump-20100519(07-39-55)-[3244].dmp
Action Log:
00 0x4BF395B6 0x00000210 0x00000000 0x00000000
01 0x4BF395AB 0x7EF40001 0x34346D56 0x21965DF8
Exception code: C0000005 ACCESS_VIOLATION reading location: 60340000
Fault address: 4C0B021D 06:0009221D MEP.dll
Registers:
EAX:0012FCF0
EBX:79012218
ECX:07433880
EDX:00410001
ESI:60340000
EDI:FFFFFFFF
CS:EIP:001B:4C0B021D
SS:ESP:0023:0012FC90 EBP:0012FD30
DS:0023 ES:0023 FS:003B GS:0000
Flags:00010213
Floating point Registers:
CTRL:027F STAT:0020 TAGS:FFFF
CS:EIP:001B:69631235
DS:EDO:0023:0C007948
Cr0NpxState:00000000
ST(0) = --------- EMPTY ---------- [0012FD6000000001] [0]
ST(1) = --------- EMPTY ---------- [000000000012FD44] [1]
ST(2) = --------- EMPTY ---------- [00000000BF193BD3] [2]
ST(3) = --------- EMPTY ---------- [0018900000000000] [3]
ST(4) = --------- EMPTY ---------- [0000000000000000] [4]
ST(5) = --------- EMPTY ---------- [0000003BB3E1EB00] [5]
ST(6) = --------- EMPTY ---------- [0012FE0400000000] [6]
ST(7) = --------- EMPTY ---------- [C3EA963000000000] [7]
Disassembly
4C0B01F7 50 push eax
4C0B01F8 8D442460 lea eax,[esp+0x60] ss:4E234973=45C6FFFF
4C0B01FC 64A300000000 mov fs:[00000000],eax fs:00000000=????????
4C0B0202 8B742470 mov esi,[esp+0x70] ss:4E234973=45C6FFFF
4C0B0206 85F6 test esi,esi
4C0B0208 8B5C2474 mov ebx,[esp+0x74] ss:4E234973=45C6FFFF
4C0B020C 0F84B2010000 je 4C0B03C4
4C0B0212 83CFFF or edi,0xFF
4C0B0215 3BF7 cmp esi,edi
4C0B0217 0F84A7010000 je 4C0B03C4
FAULT ->4C0B021D 66813E4D5A cmp word ptr [esi],0x5A4D ds:60340000=????
4C0B0222 7407 jz 4C0B022B
4C0B0224 6A7E push 0x7E
4C0B0226 E99B010000 jmp 4C0B03C6
4C0B022B 8B4E3C mov ecx,[esi+0x3C] ds:AE444CE2=033C4E8B
4C0B022E 03CE add ecx,esi
4C0B0230 813950450000 cmp dword ptr [ecx],0x4550 ds:07433880=4C02579C
4C0B0236 894C2418 mov [esp+0x18],ecx ss:4E234973=45C6FFFF
4C0B023A 75E8 jnz 4C0B0224
4C0B023C 8B6978 mov ebp,[ecx+0x78] ds:55538562=????????
4C0B023F 85ED test ebp,ebp
4C0B0241 0F847D010000 je 4C0B03C4
Call stack:
0x4C0B021D!MEP.dll + 721437 (MEP::ItemEnumerator::`vftable' + 658313 bytes)
0x769E032F!ole32.dll + 328495 (CoFreeUnusedLibrariesEx + 210 bytes)
0x769E028B!ole32.dll + 328331 (CoFreeUnusedLibrariesEx + 46 bytes)
0x769E00B5!ole32.dll + 327861 (CoFreeUnusedLibraries + 9 bytes)
0x00E7CD60!ArchiCAD.exe + 10997088 (GS::ExecutorForTT::~ExecutorForTT + 1222595 bytes)
0x4E07D503!GSRoot.dll + 185603 (GS::Main + 66 bytes)
0x01540619!ArchiCAD.exe + 18089497 (GS::ExecutorForTT::~ExecutorForTT + 8315004 bytes)
0x0153F6AD!ArchiCAD.exe + 18085549 (GS::ExecutorForTT::~ExecutorForTT + 8311056 bytes)
0x7C817077!kernel32.dll + 94327 (RegisterWaitForInputIdle + 73 bytes)
The COM Code
namespace MyInterop
/// <summary>
/// Summary description for Class1.
/// </summary>
[Guid("3E0E2EB2-CC13-40fb-9346-34809CB2418C")]
public interface IMyDotNetInterface
void ShowDialog();
[ClassInterface(ClassInterfaceType.None)]
[Guid("3A13EB34-3930-4e06-A3EB-10724CCC2F4B")]
public class MyDotNetClass : IMyDotNetInterface
public MyDotNetClass()
public void ShowDialog()
MessageBox.Show("I am a Managed DotNET C# COM Object Dialog");
‎2010-05-19 01:33 PM
wcyoot wrote:Don't use C#, .NET, or COM in add-ons. There are two reasons for advice:
I use the com just like this.
‎2010-05-19 01:45 PM
‎2010-05-19 02:22 PM
Sergey.Babitsky wrote:Yes - don't use C#. It isn't designed for this kind of development. Why not move to C++?
we using c# + addon
and yes, it's crashing when closing AC
any ideals how to solve this problem... ?
‎2010-05-19 02:28 PM
‎2010-05-19 02:35 PM
Sergey.Babitsky wrote:Yes, you should definitely run your application outside of ArchiCAD and write an add-on (in C/C++) to manage communication between them. I've written several add-ons for this purpose.
because we have a huge application (can be used as standalone) which connecting to ArchiCAD for gathering data. so, we need bridge between c++ addon and our application, written on c#
so, any ideas?
‎2010-05-19 02:41 PM
Ralph wrote:we have add-on (c++) for archicad which communicating with our application by COM.Sergey.Babitsky wrote:Yes, you should definitely run your application outside of ArchiCAD and write an add-on (in C/C++) to manage communication between them. I've written several add-ons for this purpose.
so, any ideas?
‎2010-05-19 02:46 PM
‎2010-05-19 03:14 PM
Sergey.Babitsky wrote:I'm happy to use any language or technology, provided it suits the context. I'm advising against C# and COM in this case because:
Ralph Wessel, why you against c# ?
c++ and c# communicating well by COM
problem just with ArchiCAD
