‎2019-05-02
09:16 PM
‎2022-10-05
01:28 PM
Daniel Kassai
'STR#' 32500 "Menu strings" {
/* [ ] */ "JHP"
/* [ ] */ "JHP1"
/* [ 1] */ "JHP1A"
/* [ 2] */ "JHP1B"
/* [ 3] */ "JHP1C"
/* [ ] */ "JHP2"
/* [ 1] */ "JHP2A"
/* [ ] */ "JHP3"
/* [ 1] */ "JHP3A"
/* [ 2] */ "JHP3B"
Solved! Go to Solution.
‎2019-05-03 11:09 AM
'STR#' 32500 "JHP1 menu" {
/* [ ] */ "JHP"
/* [ ] */ "JHP1"
/* [ 1] */ "JHP1A"
/* [ 2] */ "JHP1B"
/* [ 3] */ "JHP1C"
'STR#' 32501 "JHP2 menu" {
/* [ ] */ "JHP"
/* [ ] */ "JHP2"
/* [ 1] */ "JHP2A"
'STR#' 32502 "JHP3 menu" {
/* [ ] */ "JHP"
/* [ ] */ "JHP3"
/* [ 1] */ "JHP3A"
/* [ 2] */ "JHP3B"
Then register each successive menu in the same way as the original 32500, but using the relevant resource ID
‎2019-05-02 09:52 PM
‎2019-05-02 10:33 PM
// RegisterInterface
// Interface definitions
GSErrCode __ACENV_CALL RegisterInterface (void)
GSErrCode err = ACAPI_Register_Menu (32500, 32510, MenuCode_UserDef, MenuFlag_Default);
if (err != NoError)
ACAPI_WriteReport ("RegisterInterface() ACAPI_Register_Menu failed\n", false);
return err;
} // RegisterInterface
‎2019-05-02 11:19 PM
‎2019-05-03 10:54 AM
/* [ ] */ "JHP"
/* [ ] */ "JHP1"
/* [ 1] */ "JHP1A"
/* [ 2] */ "JHP1B"
/* [ 3] */ "JHP1C"
/* [ ] */ "JHP"
/* [ ] */ "JHP2"
/* [ 1] */ "JHP2A"
/* [ ] */ "JHP"
/* [ ] */ "JHP3"
/* [ 1] */ "JHP3A"
/* [ 2] */ "JHP3B"
‎2019-05-03 08:48 PM
Ralph wrote:Ralph's right, you have to create 3 different string table resources for this purpose.
A menu in the API consists of a single title heading up a list of items. It can't contain another heading underneath it.
/* [ ] */ "JHP"
/* [ ] */ "JHP1"
/* [ 1] */ "JHP1A"
/* [ 2] */ "JHP1B"
/* [ 3] */ "JHP1C"
/* [ ] */ "JHP"
/* [ ] */ "JHP2"
/* [ 1] */ "JHP2A"
/* [ ] */ "JHP"
/* [ ] */ "JHP3"
/* [ 1] */ "JHP3A"
/* [ 2] */ "JHP3B"
In the C++ code you must register 3 menus in the RegisterInterface function (using MenuCode_UserDef flag) and you can initialize the same callback function for all of your menus in the Initialize function:
GSErrCode err = NoError;
err = ACAPI_Register_Menu (32500, 0, MenuCode_UserDef, MenuFlag_Default);
err = ACAPI_Register_Menu (32501, 0, MenuCode_UserDef, MenuFlag_Default);
err = ACAPI_Register_Menu (32502, 0, MenuCode_UserDef, MenuFlag_Default);
return err;
GSErrCode __ACENV_CALL Initialize (void)
err = ACAPI_Install_MenuHandler (32500, MenuCommandHandler);
err = ACAPI_Install_MenuHandler (32501, MenuCommandHandler);
err = ACAPI_Install_MenuHandler (32502, MenuCommandHandler);
return err;
Finally your menu command handler function should look something like this:
GSErrCode __ACENV_CALL MenuCommandHandler (const API_MenuParams* params)
switch (params->menuItemRef.menuResID) {
case 32500: {
switch (params->menuItemRef.itemIndex) {
case 1: JHP1A (); break;
case 2: JHP1B (); break;
case 3: JHP1C (); break;
break;
case 32501: {
case 1: JHP2A (); break;
break;
case 32502: {
case 1: JHP3A (); break;
case 2: JHP3B (); break;
break;
return NoError;
‎2019-05-07 12:46 AM
‎2019-05-09 10:50 PM
// in the .grc file
/* Text appearing in the menu */
/* [ ] */ "JHP"
/* [ ] */ "JHP1"
/* [ 1] */ "JHP1A"
/* [ 2] */ "JHP1B"
/* [ 3] */ "JHP1C"
'STR#' 32501 "Menu strings" {
/* [ ] */ "JHP"
/* [ ] */ "JHP2"
/* [ 1] */ "JHP2A"
'STR#' 32502 "Menu strings" {
/* [ ] */ "JHP"
/* [ ] */ "JHP3"
/* [ 1] */ "JHP3A"
/* [ 2] */ "JHP3B"
// in the main.cpp file
// Command executed by menu choices
void ShowMessage(char argv[])
MessageBox(0, argv, "Menu choice made is...", MB_OK);
// Handles menu commands
GSErrCode __ACENV_CALL MenuCommandHandler(const API_MenuParams *menuParams)
switch (menuParams->menuItemRef.menuResID) {
case 32500: {
switch (menuParams->menuItemRef.itemIndex) {
case 1: ShowMessage("1A"); break;
case 2: ShowMessage("1B"); break;
case 3: ShowMessage("1C"); break;
break;
case 32501: {
case 1: ShowMessage("2A"); break;
break;
case 32502: {
case 1: ShowMessage("3A"); break;
case 2: ShowMessage("3B"); break;
break;
return NoError;
// MenuCommandHandler
GSErrCode __ACENV_CALL RegisterInterface(void)
err = ACAPI_Register_Menu(32500, 0, MenuCode_UserDef, MenuFlag_Default);
err = ACAPI_Register_Menu(32501, 0, MenuCode_UserDef, MenuFlag_Default);
err = ACAPI_Register_Menu(32502, 0, MenuCode_UserDef, MenuFlag_Default);
return err;
// Initialize
// Called when the Add-On has been loaded into memory
// to perform an operation
GSErrCode __ACENV_CALL Initialize(void)
err = ACAPI_Install_MenuHandler(32500, MenuCommandHandler);
err = ACAPI_Install_MenuHandler(32501, MenuCommandHandler);
err = ACAPI_Install_MenuHandler(32502, MenuCommandHandler);
return err;
// Initialize
‎2019-05-10 07:35 PM
