Archicad C++ API
No debug information after AC23 compilation
I have tired to compile Geometry_Test example project with VS2017(v141) as Debug, but it provide a warning message like below.
1>------ Rebuild All started: Project: Geometry_Test, Configuration: Release x64 ------
1>Compiling the localized GRC file...
1>Compiling the non-localized GRC file...
1>Compiling the RC2 file...
1>Microsoft (R) Windows (R) Resource Compiler Version 6.3.9600.17336
1>
1>Copyright (C) Microsoft Corporation. All rights reserved.
1>
1>
1>APICommon.c
1>Geometry_Test.cpp
1>Generating Code...
1> Creating library Build\x64\Release\Geometry_Test.lib and object Build\x64\Release\Geometry_Test.exp
1>ACAP_STAT.lib(ACAPlib.obj) : warning LNK4099: PDB 'API_c.pdb' was not found with 'ACAP_STAT.lib(ACAPlib.obj)' or at 'd:\Work\buildsupport\AC23Support\Examples\Geometry_Test\Build\x64\Release\API_c.pdb'; linking object as if no debug info
1>Geometry_Test.vcxproj -> D:\Work\buildsupport\AC23Support\Examples\Geometry_Test\Build\x64\Release\Geometry_Test.apx
1>Done building project "Geometry_Test.vcxproj".
========== Rebuild All: 1 succeeded, 0 failed, 0 skipped ==========
Please advice.
Don't worry – you can ignore that warning. It's only advising that you won't be able to debug as effectively into certain API libraries because the debug information isn't bundled with them, but you wouldn't want to do that anyway.
Ralph Wessel BArch
Central Innovation
1 REPLY 1
Ralph Wessel BArch
Central Innovation
