2020-07-31
11:29 AM
2021-09-15
09:55 AM
Noemi Balogh
Solved! Go to Solution.
2020-08-03 05:17 AM
2020-07-31 12:58 PM
2020-08-03 04:22 AM
Ralph wrote:Thank you. But I thought I has set some path used by compiler. Is there a specific path that is connected with resources file?
The most likely problem is that the project is now in a different position relative to the dev-kit. Add-on resources use a platform-neutral format that is converted to native resources during the build process. The path to the converter is usually relative to the project, so if you moved somewhere where the relative path is broken, the resources won't be converted and compiler won't be able to find the required platform-specific resource files.
2020-08-03 05:17 AM
