‎2009-07-09
10:12 AM
‎2023-08-03
01:42 PM
Doreena Deng
Add Wall 1: begC = 25.730653762817, -1.115708112717; endC = 23.361846923828, 1.253100752831; height = 2.8; thickness = 0.35; thickness1 = 0.35; top = -0.87; Add Wall 2: begC = 23.361846923828, 1.253100633621; endC = 18.963642120361, 5.651303291321; height = 2.8; thickness = 0.47; thickness1 = 0.47; top = -0.87; Add Window to Wall 2: libName = W1 Casement 12 width = 0.999999940395; height = 1.039999961853; objLoc = 1.065259099007; lower = 1.060000181198; oSide = true; refSide = true; reflected = false;
‎2009-07-14 05:02 PM
graffiti wrote:Can you post a screen-grab to illustrate what you mean when you say the window is "outside the wall"?
I add two walls and an window using the DevToolkit (12.2156).
The window is placed outside the wall.
‎2009-07-19 12:19 PM
‎2009-07-21 11:56 PM
graffiti wrote:Go to the Attribute Manager and purge ALL unused attributes.
Since the window in placed so far from the wall, all you will see is just two small dots.
I have a small PLN file which show the problem, but I don't know how to post it (too big, in zip it is 488KB)
‎2009-07-22 08:56 AM
‎2009-07-22 06:12 PM
‎2009-07-22 08:04 PM
graffiti wrote:There doesn't seem to be a window in the model at all. At what coordinates does the window appear?
Here is the zipped purged model.
‎2009-07-23 09:23 AM
