2021-07-19
09:02 AM
2021-09-14
09:26 AM
Noemi Balogh
long Get3DInfo (const API_Guid& guid) {
DBASSERT (APINULLGuid != guid);
m_Guid = guid;
BNZeroMemory (&m_info3D, sizeof (API_ElemInfo3D));
API_Elem_Head elemHead;
BNZeroMemory (&elemHead, sizeof (API_Elem_Head));
elemHead.guid = m_Guid;
ACAPI_Element_GetHeader (&elemHead);
m_err = ACAPI_Element_Get3DInfo (elemHead, &m_info3D);
if (m_err == APIERR_BADID)
return 0;
if (m_err == APIERR_GENERAL)
return 0;
if (m_err != NoError)
ErrorBeep ("Error in ACAPI_Element_Get3DInfo", m_err);
return 0;
m_nBody = m_info3D.lbody - m_info3D.fbody + 1;
if (m_nBody > 0) GetBody (m_info3D.fbody);
return m_nBody;
bool GetBody (long bodyIndex)
DBASSERT (APINULLGuid != m_Guid);
DBASSERT (bodyIndex > 0);
DBASSERT (bodyIndex >= m_info3D.fbody && bodyIndex <= m_info3D.lbody);
BNZeroMemory (&m_component, sizeof (API_Component3D));
m_component.header.typeID = API_BodyID;
m_component.header.index = bodyIndex;
m_err = ACAPI_3D_GetComponent (&m_component); // ACAPI_3D_GetComponent return APIERR_DELETED in Archicad24
if (m_err == APIERR_DELETED)
m_err = NoError;
return false;
return true;
Solved! Go to Solution.
2021-07-19 09:26 AM
for (int i = 0; i < BMpGetSize((GSPtr)(memo.columnSegments)) / sizeof(API_ColumnSegmentType); i++)
Get3DInfo(memo.columnSegments.head.guid);
2021-07-19 09:26 AM
2021-07-19 11:03 AM
leilei wrote:Thank you. It works!
Hi,Maybe the element is column、beam.When you get the guids of beams and columns.You should traverse the sub elements in memo.columnSegments or memo.beamSegments.for (int i = 0; i < BMpGetSize((GSPtr)(memo.columnSegments)) / sizeof(API_ColumnSegmentType); i++) { Get3DInfo(memo.columnSegments.head.guid); }
