ReignBough
ProfileVectorImage polygon operation
Is there an intersection (and other polygon) operation for ProfileVectorImage? Currently I am using:
try { pvi.GetVectorImage().Strip(cutPoly, &vi); }
catch (const GS::Exception& e) { WriteReport("%s", e.GetMessage().ToCStr().Get()); };
vi.CheckAndRepair();
pvi is the source ProfileVectorImage;
vi is the output VectorImage;
cutPoly is the IrregularPolygon2D that counts as a cutter;
But it sometimes crashes.
~ReignBough~
ARCHICAD 27 INT (since AC18)
Windows 11 Pro, AMD Ryzen 7, 3.20GHz, 32.0GB RAM, 64-bit OS
1 Solution
Akos Somorjai
Have you tried to copy the source?
VectorImage vecIm = pvi.GetVectorImage ();
vecIm.Strip (cutPoly, &vi);
If it still crashes, could you please write it to an XML file, and send me that?
Thanks, Akos
Go to post
3 Replies 3
Akos Somorjai
Thanks, Akos
ReignBough
That was the original code but it also crashes. Then I made some changes (not only on that part but also on some other part of the code) and still crashes.
Now, I changed that part back to what you suggest. Now it is working.
Thanks.
~ReignBough~
ReignBough
BTW, is there a "Strip" function for ProfileVectorImage ?
~ReignBough~
