Archicad C++ API
Publish current ArchiCAD project on Sharepoint site
I would like to develop an addon that would publish the current project on a SharePoint website.
I successfully did it for Revit thanks to the Microsoft SharePoint Client library (C#).
Do you think it is possible to do the same with C++-based ArchiCAD ?
Thanks for your help.
5 REPLIES 5
Not directly, but there's probably a workaround. Your existing method with Revit wouldn't work on a cross-platform application like Archicad (Revit is locked into Windows).
I can think of several possibilities:
1) Write a stand-alone .Net-based tool that you invoke from your add-on, passing whatever parameters are required to upload the target project
2) I think the deprecated RPC API for Sharepoint could potentially be called from an add-on - see https://msdn.microsoft.com/library/4aa5c82b-90fb-4be5-b30c-d35ecae42a81%28Office.15%29.aspx
3) You might be able to leverage one of the other APIs, e.g. Javascript, indirectly (similar to point 1, but you might not need a full application).
Ralph Wessel BArch
Central Innovation
Thanks for the suggestions.
Do you think I could write a Python script that does the job and that would be executable from the new "Python palette" in ArchiCAD ?
I'm not sure if the Archicad Python API is capable of that. But you could write an external python script and invoke it from an add-on (passing the relevant parameters). It also depends on whether there is a suitable python library for interacting with Sharepoint (otherwise you don't gain anything). Bear in mind that any language use relying on .Net won't work directly in Archicad - otherwise you could do it in C++ too. The primary problem is that MS designs its software to limit interaction in a platform-neutral way. That situation is improving, but I don't believe .Net will every be a level playing field across platforms.
Ralph Wessel BArch
Central Innovation
There is a Sharepoint library in Python that can be used to upload a document on a Sharepoint site. The question is : will I be able to call my Python script from ArchiCAD ?
If not, I'd be better trying to do it in C++ directly.
hi,
we are looking also for a way to publish Archicad documentations directly to SharePoint.
You know of a way to implement BIMx model viewer into a SharePoint website?
AC24 4018 INT, Win10, Quadro P2000, Xeon, BIMCloud
