2017-08-30
07:55 PM
2022-12-06
02:00 PM
Daniel Kassai
2017-08-31 11:18 PM
2017-09-12 02:24 PM
vuego wrote:
I've noticed that there is a XML engine included with AC Api in GSRoot module.
vuego wrote:
Secondly, is there a preferred "AC API" way to execute a http request from a plugin? An example would be great too.
2017-09-12 03:09 PM
2017-09-18 11:28 AM
Response response; GS::IChannelX channel(clientConnection.BeginReceive(response), GS::GetNetworkByteOrderIProtocolX());I would like to store binary response to a file object IO::File..
IO::Location rab("C:/GDLTest/11204.gsm2");
IO::File targetFile(rab, IO::File::Create);
How can I store data from GS::ChanelX into IO::File?2017-09-18 11:35 AM
vuego wrote:The 'I' in IChannel stands for input channel. You have to open an output channel (GS::OChannel), which can be an IO::File, then write the data directly into it.
I have another question. I am getting binary data with my http request into GS::IChannelX. My binary data is a gsm object.
Or, is it possible to use IO::File as IChannel and store request directly to file using clientConnection.BeginReceive(response) ?
Thank you in advance.
2017-09-18 12:10 PM
2017-09-18 12:56 PM
vuego wrote:Again: IChannels are for input OChannel are for output. The http connection is the input channel, and you yourself have to write that information to the output channel (== IO::File). So the pseudo code:
Sorry, I ment IO::File as output channel.
I am having trouble receiving/writing data from HTTP::ClientConnection directly into IO::File (GS::OChannel)... how do I achieve that?
2017-09-18 01:09 PM
