2016-03-07 08:18 AM - last edited on 2023-07-13 02:30 PM by Doreena Deng
2016-03-18 06:45 PM
Erenford wrote:Hotlinked elements also have the hotlinkGuid member set in their element header, whereas user-grouped elements don't.
How do you tell if the element is grouped by the user or is merely just inside a hotlink module? What I use is if there is agroupGuidvalue present although hotlinked elems also have a groupGuidand are being considered by ACAPI_ElementGroup_GetGroupedElemsas a legit group even if they weren't grouped by the user and are just part of a hotlink.
UsingACAPI_ElementGroup_GetGroupedElems(groupGuid):
- Grouped elems (hotlinked or not) returns their immediate elems => this is what I need
- Non-grouped non-hotlinked elems have no groupGuid thus ignored => also ok
- Non-grouped hotlinked elems have a groupGuid and will return immediate elems (all fellow hotlinked elems) => not ok, I don't need this
Basically what I need are elements that are grouped only by the user regardless if its in a hotlink module or not, and any non-grouped elems (hotlinked and otherwise) should be ignored. Any Ideas?
2016-03-29 08:53 AM
Akos wrote:Yes, but what I'm having problems with is when it is BOTH grouped and hotlinked. For example:
Best, Ákos
