Archicad C++ API
[SOLVED] Dockable palette - is it possible?
Is it possible to create a dockable custom palette like Info Box - in the other words, is it possible to create a window, which can be made floating or docked to some side of the working area?
Thanks.
24 REPLIES 24
ReignBough
Where/How to initialize Palette::SelectionChanged using ACAPI_Notify_CatchSelectionChange?
~ReignBough~
ARCHICAD 27 INT (since AC18)
Windows 11 Pro, AMD Ryzen 7, 3.20GHz, 32.0GB RAM, 64-bit OS
Tibor Lorantfy
I think it's better if SelectionChanged belongs to PaletteObserver, and then you can initialise it in PanelOpened function like this:
GSErrCode __ACENV_CALL	PaletteObserver::SelectionChanged (const API_Neig* selElemNeig)
void PaletteObserver::PanelOpened (const DG::PanelOpenEvent& /*ev*/)
	ACAPI_Notify_CatchSelectionChange (SelectionChanged);
void PaletteObserver::PanelClosed (const DG::PanelCloseEvent& /*ev*/)
	ACAPI_Notify_CatchSelectionChange (NULL);
Best Regards,
Tibor
ReignBough
how to catch the dock/undock events?
~ReignBough~
Tibor Lorantfy
Please visit the following topic, I answered the question there:
http://archicad-talk.graphisoft.com/viewtopic.php?t=47543
ReignBough
Thanks. That's a big help.
~ReignBough~
