Miha Nahtigal
[SOLVED] From .gsm file to embedded library
What would be the best way to store a .gsm file as a new API_LibPart object in embedded library?
Is it possible to fill LibPart sections from gsm file?
Currently I am adding a new linked library APIEnv_AddLibrariesID, search for object by name with ACAPI_LibPart_Search and copy sections manually to a new libpart created with ACAPI_LibPart_Create... which is a bit tedious, besides I cannot remove linked /tmp/ library.
BIMquants - Free Plugin for Quantities and Costs Estimation in Archicad | BIMrender - Free & Open Source Plugin for AI rendering in Archicad
Miha Nahtigal
Found a solution:
IO::Location rab("C:/GDLTest/11204.gsm");
	GSErrCode err;
	auto folderId = API_SpecFolderID::API_EmbeddedProjectLibraryFolderID;
	IO::Location embeddedLibraryFolder;
	if (ACAPI_Environment(APIEnv_GetSpecFolderID, &folderId, &embeddedLibraryFolder) == NoError && IO::Folder(embeddedLibraryFolder).GetStatus() == NoError) {
		// copy file to embedded folder
		IO::Location destFolder = embeddedLibraryFolder;
		destFolder.AppendToLocal(IO::Name("11204.gsm"));
		err = IO::fileSystem.Copy(rab, destFolder);
		API_LibPart libPart;
		BNZeroMemory(&libPart, sizeof(API_LibPart));
		libPart.typeID = APILib_ObjectID;
		libPart.location = &destFolder;
		err = ACAPI_LibPart_Register(&libPart);
Akos Somorjai
vuego wrote:
Found a solution:
Alternatively, you can create a new library part (ACAPI_LibPart_Create), that puts it directly into the embedded library. Also, you can assemble the library part with ACAPI_LibPart_AddSection or ACAPI_LibPart_NewSection calls.
Best, Akos
