Archicad C++ API
[SOLVED] Is there File chooser dialog class or method
Hi there
I would like to know is there a class or method to open file chooser dialog ?
Thanks in advance!
Tibor Lorantfy
Graphisoft Alumni
Graphisoft Alumni
Yes, you can use DG::FileDialog for opening or saving files.
Here is an example code for you (copied from Communication_Manager example Add-On):
static bool	GetOpenFile (IO::Location*	dloc, const char* fileExtensions, const GS::UniString& filterText)
	FTM::TypeID	retID;
	FTM::FileTypeManager	ftman ("MyManager");
	FTM::FileType			type (NULL, fileExtensions, 0, 0, 0);
	FTM::TypeID				id = FTM::FileTypeManager::SearchForType (type);
	if (id == FTM::UnknownType)
		id = ftman.AddType (type);
	DG::FileDialog	dlg (DG::FileDialog::OpenFile);			// Open only 1 file
	UIndex	i = dlg.AddFilter (id, DG::FileDialog::DisplayExtensions);	// Force it on mac...
	dlg.SetFilterText (i, filterText);
	if (dlg.Invoke ()) {
		*dloc = dlg.GetSelectedFile ();
		return (true);
	} else
		return (false);
// Using:
	IO::Location dwgFileLoc;
	if (!GetOpenFile (&dwgFileLoc, "dwg", "*.dwg"))
		return;
	IO::Name	dwgName;
	dwgFileLoc.GetLastLocalName (&dwgName);
Note that the type of the FileDialog could be the followings: (see in DGFileDialog.hpp)
	enum Type {
		OpenFile,
		OpenMultiFile,
		OpenFolder,
		OpenMultiFolder,
		Save
Regards,
Tibor
Hi.
Thank you for the quick response.
