2015-01-21
01:50 PM
- last edited on
2023-08-01
01:53 PM
by
Doreena Deng
// Set/adjust the dialog items
static void ListDataDlg_Set (short dialId, DGUserData userData)
API_ListData listdata;
char keyStr[NAME_LEN2];
char codeStr[NAME_LEN2];
Int32 count;
Int32 i;
bool filter;
if (userData == 0L) {
return;
listdata = *((API_ListData *) (userData));
listdata.header.setIndex = (short) DGPopUpGetItemUserData (dialId, DBSetPopupItem,
(short) DGGetItemValLong (dialId, DBSetPopupItem));
GS::UniString temp = DGGetItemText (dialId, KeyEditTextItem);
CHTruncate (UniStringToConstCString (temp), keyStr, NAME_LEN2);
temp = DGGetItemText (dialId, CodeEditTextItem);
CHTruncate (UniStringToConstCString (temp), codeStr, NAME_LEN2);
switch (DGGetItemValLong (dialId, TypeIDPopupItem)) {
case 1: listdata.header.typeID = API_ComponentID;
CHCopyC (keyStr, listdata.component.keycode);
CHCopyC (codeStr, listdata.component.code);
DGEnableItem (dialId, KeyEditTextItem);
break;
case 2: listdata.header.typeID = API_DescriptorID;
CHCopyC (keyStr, listdata.descriptor.keycode);
CHCopyC (codeStr, listdata.descriptor.code);
break;
case 3: listdata.header.typeID = API_KeyID;
CHCopyC (codeStr, listdata.key.code);
DGDisableItem (dialId, KeyEditTextItem);
break;
case 4: listdata.header.typeID = API_UnitID;
CHCopyC (codeStr, listdata.unit.code);
break;
DGListDeleteItem (dialId, SearchListItem, DG_ALL_ITEMS);
filter = (DGGetCheckedRadio (dialId, 1) == FilterRadioItem);
Search_ListData (&listdata, &count, filter);
if (count < 1 || listHdl == NULL)
return;
for (i = 1; i <= count; i++)
DGListInsertItem (dialId, SearchListItem, DG_LIST_BOTTOM);
SetDGList (dialId, count);
DGListSelectItem (dialId, SearchListItem, 1);
return;
} // ListDataDlg_Set
static void Search_ListData (API_ListData *param, Int32 *count, bool filter)
Int32 i;
Int32 beginIndex, endIndex;
GSErrCode err;
listdata = *param;
*count = 0;
err = NoError;
/* ACAPI_ListData_Search fails if keyCode is an empty string */
/* ------- Search it ------- */
if (filter && (param->header.typeID == API_UnitID || param->header.typeID == API_KeyID ||
(param->header.typeID == API_ComponentID && strlen (param->component.code) != 0) ||
(param->header.typeID == API_DescriptorID && strlen (param->descriptor.code) != 0))) {
err = ACAPI_ListData_Search (&listdata);
if (err == NoError)
err = ACAPI_ListData_Get (&listdata);
if (err == NoError) {
err = AppendList (&listdata, count);
if (listdata.header.typeID == API_DescriptorID)
BMKillHandle (&listdata.descriptor.name);
} else {
/* ------ Search list ------ */
if (filter) {
if (err != NoError)
return;
beginIndex = listdata.header.index;
} else
beginIndex = 1;
err = ACAPI_ListData_GetNum (param->header.setIndex, param->header.typeID, &endIndex);
if (err != NoError)
return;
BNZeroMemory (&listdata, sizeof (API_ListData));
listdata.header.typeID = param->header.typeID;
listdata.header.setIndex = param->header.setIndex;
for (i = beginIndex; i <= endIndex; i++) {
listdata.header.index = i;
if (err != NoError)
break;
if (filter) {
if (listdata.header.typeID == API_ComponentID &&
!CHEqualCStrings (listdata.component.keycode, param->component.keycode))
break;
if (listdata.header.typeID == API_DescriptorID &&
!CHEqualCStrings (listdata.descriptor.keycode, param->descriptor.keycode)) {
break;
if (err != NoError)
return;
return;
} // Search_ListData
But how can I group those items under a header like in the example.2015-01-28 04:03 AM
2015-01-28 09:14 AM
2015-08-20 08:54 AM
bool isOpen = false;
//... clear list before loop
for (... i = 0; i < cnt; i++)
if (flags & API_ParFlag_Hidden)
continue;
// check if parent or child
if (flags & API_ParFlag_Child)
// skip if parent is "close"
if (!isOpen)
continue;
// set isOpen if item is not child
else
isOpen = (flags & API_ParFlag_Open) > 0;
//... populate list here checking if it is disabled, bold, separator, etc.
2015-08-21 12:11 PM
