Service alert: BIMcloud SaaS disruption in the US Read more
Archicad C++ API
Some doubts in Example 3D_Test
sxs
Hi,everyone:
  I am trying to export geometry, so I plan to refer to Example 3D_Test(Examples\3D_Test\Src\3D_Test.c)。
  But I have a few doubts after reading the code:
    1. I know you want to transform a vertex to a Local coordinate system, but during the Enumerate, the conts[0][0] will change. Can this code achieve its purpose?
  2, if nConts == 1 (this should mean polygon has no hole?), and how should I handle this situation?
sxs
"if(nConts > 1)" change to "if(nConts >= 1)"
sxs
this code is in DumpBody.
sxs
