Streamline your workflows and master BIM coordination! Program starts April 28.!
Archicad C++ API
The Add-On cannot be loaded
yyy1104
I was trying to build the maze generator add on from the Graphisoft tutorial, but after I built the .apx file successfully and upload to the ArchiCad add on folder, the add on manager showed that the add-on cannot be loaded. Given that I have provided the "MDID" with my Developer ID and Local ID.
Joel Buehler
Stupid Questions:
- Does the Addon run in Demomode?
- Where have you given the Id? in the Cmake Text file?
Hi Joel Buehler,
I also built the .apx file successfully, but when I load it into ArchiCAD it doesn't appear in the list of Addons. I using ArchiCAD 25 (not using Demomode). And I give the ID in AddOnFix grc file.
Thanks in advance.
