Denny Wong
UI_RADIOBUTTON ignoring second array index
Hi All,
I am trying to use UI_RADIOBUTTON with a 2 dimensional array parameter. However if I ask for _param[i][j], it will always store the value in [i][i] instead, making this command useful in the diagonal matrix only.
I hope I am not missing something obvious - but this appears to be a bug to me...?
Many thanks in advance, I'll love to hear your thoughts.
UI_RADIOBUTTON stores values into [2][2], not [2][3] as specifiedUI_RADIOBUTTON stores values into [2][2], not [2][3] as specified
Tested in AC23 and AC25, latest patches.
1 Solution
Peter Baksa
Yes, this is a bug, thank you for reporting. It will be fixed in the next version (AC26).
Péter Baksa
Software Engineer, Library
Graphisoft SE, Budapest
Go to post
11 Replies 11
You should use  UI_RADIOBUTTON{2} to be able to use matrix parameters with it.
Piotr
Denny Wong
Hi Piotr, many thanks for your reply. I thought UI_RADIOBUTTON{2} only take string expression for the parameter and its not taking "someintegers[2][3]" nor someintegers[2][3]. Am I missing something?
Thanks in advance.
remove quotes
UI_RADIOBUTTON{2}
Compatibility: introduced in Archicad 20.
UI_RADIOBUTTON{2} "name", value, text, x, y, width, height
Generates a radio button of a radio button group. Radio button groups are defined by the parameter name.
Items in the same group are mutually exclusive.
name: parameter name as string expression for UI_RADIOBUTTON{2} or parameter name with optional actual index values if array for UI_RADIOBUTTON.
value: parameter is set to this value if this radio button is set.
text: this text is displayed beside the radio button.
x, y: the position of the radio control.
width, height: width and height in pixels.
the above comes from:
https://gdl.graphisoft.com/reference-guide/the-user-interface-script
I know it is not clear... but the same aplies to ui_infield's and so on.
Denny Wong
Thanks Piotr, I am aware of the difference between UI_INFIELD and UI_INFIELD{2} / UI_INFIELD{3} and UI_INFIELD{4}. And from that I am fairly certain that UI_RADIOBUTTON is in fact the right one to use - as it states clearly:
  • parameter name as string expression for UI_RADIOBUTTON{2}
  • or
  • parameter name with optional actual index values if array for UI_RADIOBUTTON
Basically UI_RADIOBUTTON works like UI_INFIELD{2} and UI_RADIOBUTTON{2} works like UI_INFIELD. Very inconsistent but well that's GDL.
Just to be very clear what would happen:
Sorry I did not do a test...it works with original one...
 Parameter is integer
UI_RADIOBUTTON{2} integerArray[1][1], 513, `test Value1`, 10, 140, 100, 20
UI_RADIOBUTTON{2} integerArray[2][2], 1513, `test Value2`, 10, 160, 100, 20
Denny Wong
No worries, thanks Piotr. Now if you just quickly try again with integerArray[1][2] and integerArray[2][1], see if you get the correct results?
there is some..."consistency" 😛
UI_RADIOBUTTON integerArray[1][1], 513, `test Value11`, 10, 140, 100, 20
UI_RADIOBUTTON integerArray[1][1], 515, `test Value21`, 10, 160, 100, 20
UI_RADIOBUTTON integerArray[1][2], 1515, `test Value12`, 10, 180, 100, 20
UI_RADIOBUTTON integerArray[2][2], 1513, `test Value22`, 10, 200, 100, 20
It seems that it can set column wise.. test this and You will see...
I do not know if it is a bug or feature
