Jochen Suehlo
Can Objects ignore graphical overwrites
Is it possible that GDL Objects can ignore grafical overwrites?
Example: I want to overwrite all my furniture in the Electrical installation plan with no fill and grey contour pen. I do not want to overwrite the electrical symbols that are also GDL objects.
Jochen Suehlo . AC12-29 . MAC OSX 14.4 . WIN11
GDL object creation: b-prisma.de
1 Solution
Maybe modify your Graphic Override Rule criteria so they will not apply to you desired Library Parts.
For example, you can create a Property, set this Property to a certain value for these Library part instances, and then specify your Graphic Override Rule criteria in a way that it does not override elements that have that Property with that specific value.
Go to post
Jochen Suehlo
Thank You Laszlo, I did not think in this direction. This  works well.
