ReignBough
Unable to select curtain wall on elevation view
When a curtain wall is placed below storey 0, it cannot be selected. I put two curtain wall, one on storey 0 and the other on storey -1. I then put an elevation marker in front of them. I viewed the elevation marker then select all curtain wall. Only the curtain wall on storey 0 is selected.
This is both on elevation marker and section marker. ArchiCAD 19.
~ReignBough~
ARCHICAD 27 INT (since AC18)
Windows 11 Pro, AMD Ryzen 7, 3.20GHz, 32.0GB RAM, 64-bit OS
1 Reply 1
Works for me just fine.
Are you still on build 3003? You could try upgrading to the latest build, many small errors were fixed in the hotfixes.
