Archicad C++ API
Updating Add-ons from 8.1 to 9
TomWaltz
I am trying to update an add-on I wrote for 8.1 to run on Archicad 9 on macOS 10.3.
I opened the file in Codewarrior, repointed all the support directories to the DevKit 6.1, and recompiled.
Archicad 9 tells me the add-on is outdated and will not run.
Is there a step I'm missing? Or a FAQ on this topic?
Thanks!
Tom Waltz
4 REPLIES 4
Just a guess, Tom: did you do a complete rebuild? It's possible that some old compiled resource or object files were used in the link since an ordinary 'make' wouldn't have found them out of date.
AC 29 USA and earlier   ā€¢   hardware key   ā€¢   macOS Taho 26.1 MacBook Pro M2 Max 12CPU/30GPU cores, 32GB
TomWaltz
Yeah, I did. I had thought of that as well.
Tom Waltz
TomWaltz
Whoops! Not complete enough of a rebuild!
It works!
Tom Waltz
TomWaltz wrote:
It works!
Hurray!
