2020-08-14
10:17 AM
2021-09-15
09:54 AM
Noemi Balogh
GSErrCode err;
void* newSightPtr;
err = ACAPI_3D_CreateSight(&newSightPtr);
Modeler::SightPtr * sight = reinterpret_cast<Modeler::SightPtr*>(&newSightPtr);
ModelerAPI::Model model;
AttributeReader attrReader;
// This seems to be working
DBPrintf("sight name is: %s", sight->Get()->GetName().ToCStr().Get());
Modeler::SunSettings sun = sight->Get()->GetSunSettings();
err = EXPGetModel(sight->Get()->GetConstMainModelPtr(), &model, &attrReader);
//err = EXPGetModel(*sight, &model, &attrReader);
// Both seem to work but on the next line the count is always 0.
int cnt = model.GetElementCount();
ModelerAPI::Element elem;
// strange indexing from the example
for (int i = 1; i <= cnt; i++) {
model.GetElement(i, &elem);
DBPrintf("model guid is %s", model.GetGuid().ToUniString().ToCStr().Get());
DBPrintf("elem guid is %s", elem.GetElemGuid().ToUniString().ToCStr().Get());
DBPrintf("Succesfully got element");
DBPrintf("Yaay No Segfault");
ACAPI_3D_DeleteSight(newSightPtr);
My ultimate goal would be getting the currently selected element/elements 3d information, but I've yet to find any crossover from the GUID oriented C api to this heavily object oriented c++ world.2020-08-15 12:37 AM
Modeler::SightPtr sight; err = ACAPI_3D_CreateSight((void**) &sight); ModelerAPI::Model model; AttributeReader attrReader; err = EXPGetModel(sight, &model, &attrReader);
2020-08-15 01:46 AM
2020-08-17 02:32 PM
ACAPI_3D_CreateSightfunction. If I'm using the
ACAPI_3D_GetCurrentWindowSightto get a sight object, and the perspective view is on top, it works. If I had to guess, the sight is an empty object without the database.
GSErrCode err;
//Modeler::SightPtr sight;
//err = ACAPI_3D_CreateSight((void**)&sight);
// err = ACAPI_3D_GetCurrentWindowSight((void**)&sight);
void* newSightPtr;
err = ACAPI_3D_GetCurrentWindowSight(&newSightPtr);
if (err == NoError) {
//sight.Get()->Attach(*this);
AttributeReader atr();
DBPrintf("sight name is: %s\n", sight->Get()->GetName().ToCStr().Get());
DBPrintf("model guid is %s\n", model.GetGuid().ToUniString().ToCStr().Get());
ModelerAPI::MeshBody body;
// continue if not interested guid.
if (!(guids->Contains(GSGuid2APIGuid(elem.GetElemGuid()))))
continue;
// Take a look on EdgeAttributes class.
int nBodies = elem.GetMeshBodyCount();
for (Int32 iBody = 1; iBody <= nBodies; iBody++) { // Bodies
elem.GetMeshBody(iBody, &body);
bool wire = body.IsWireBody();
bool mesh = body.IsVisibleIfContour(); // if this is true this might be a contur poly.
bool closed = body.IsClosed();
bool solid = body.IsSolidBody();
DBPrintf("These are all the vertices of %s \n", elem.GetElemGuid().ToUniString().ToCStr().Get());
Int32 vertexCnt = body.GetVertexCount();
GS::Array<ModelerAPI::Vertex> vertexContainer;
for (Int32 iVertex = 1; iVertex <= vertexCnt; iVertex++) {
ModelerAPI::Vertex vtx;
body.GetVertex(iVertex, &vtx);
vertexContainer.Push(vtx);
DBPrintf("Body vertex idx: %d [%2.1f %2.1f %2.1f] \n", iVertex, vtx.x, vtx.y, vtx.z);
DBPrintf("These are all the edges of %s \n", elem.GetElemGuid().ToUniString().ToCStr().Get());
Int32 edgeCnt = body.GetEdgeCount();
GS::Array<ModelerAPI::Edge> edgeContainer;
for (Int32 iEdge = 1; iEdge <= edgeCnt; iEdge++) {
ModelerAPI::Edge edge;
body.GetEdge(iEdge, &edge);
Int32 idV1 = edge.GetVertexIndex1();
Int32 idV2 = edge.GetVertexIndex2();
DBPrintf("Body edge nr.:%d between vertices %d - %d \n", iEdge, idV1, idV2);
DBPrintf("Body edge nr.:%d between [%2.1f %2.1f %2.1f]-[%2.1f %2.1f %2.1f] \n",
iEdge,
vertexContainer[idV1-1].x, vertexContainer[idV1-1].y, vertexContainer[idV1-1].z,
vertexContainer[idV2-1].x, vertexContainer[idV2-1].y, vertexContainer[idV2-1].z
Int32 idP1 = edge.GetPolygonIndex1();
Int32 idP2 = edge.GetPolygonIndex2();
DBPrintf("Body edge nr.:%d related to polygons %d - %d \n", iEdge, idP1, idP2);
bool cont = edge.IsVisibleIfContour();
DBPrintf("Is edge[%d] visible %s \n", iEdge, cont ? "true" : "false" );
edgeContainer.Push(edge);
Int32 polCnt = body.GetPolygonCount();
DBPrintf("These are all the Polygons of %s\n", elem.GetElemGuid().ToUniString().ToCStr().Get());
ModelerAPI::Polygon poly;
for (Int32 iPoly = 1; iPoly <= polCnt; iPoly++) {
body.GetPolygon(iPoly, &poly);
Int32 polyEdge = poly.GetEdgeCount();
for (Int32 iPEdge = 1; iPEdge <= polyEdge; iPEdge++) {
Int32 edgeIdx = poly.GetEdgeIndex(iPEdge);
DBPrintf("Edges in this [%d] pgon idx:%d \n", iPoly, edgeIdx);
for (Int32 iPVec = 1; iPVec <= polyEdge; iPVec++) {
Int32 vecIdx = poly.GetVertexIndex(iPVec);
DBPrintf("This pgon[%d] consists of vertex[%d] which is globally [%d] \n", iPoly, iPVec, vecIdx);
// 1. Seems to be returning the normal to this pgon by vertex which is good -
// 2. unreliable if there is a hole in the poly - crashes archicad
// 3. if I'm using the first vertex in each pgon its working?
ModelerAPI::Vector nVec = poly.GetNormalVectorByVertex(1, ModelerAPI::CoordinateSystem::ElemLocal);
DBPrintf("T[%2.1f %2.1f %2.1f] \n", nVec.x, nVec.y, nVec.z);
Int32 polvecCnt = body.GetPolygonVectorCount(); // Dunno what is this.
ModelerAPI::Vector bodyVec;
for (Int32 iVec = 1; iVec <= polvecCnt; iVec++) {
body.GetVector(iVec, &bodyVec, ModelerAPI::CoordinateSystem::ElemLocal);
DBPrintf("Body vector idx: %d [%2.1f %2.1f %2.1f] \n", iVec, bodyVec.x, bodyVec.y, bodyVec.z);
} // Bodies
ModelerAPI::Transformation tran = elem.GetElemLocalToWorldTransformation();
DBPrintf("TranMat\n[%2.1f][%2.1f][%2.1f]\n[%2.1f][%2.1f][%2.1f]\n[%2.1f][%2.1f][%2.1f]\n[%2.1f][%2.1f][%2.1f]\n",
tran.matrix[0][0], tran.matrix[0][1], tran.matrix[0][2],
tran.matrix[1][0], tran.matrix[1][1], tran.matrix[1][2],
tran.matrix[2][0], tran.matrix[2][1], tran.matrix[2][2],
tran.matrix[3][0], tran.matrix[3][1], tran.matrix[3][2]);
else
DBPrintf(ErrID_To_Name(err));
if (newSightPtr != nullptr)
This output was made for a simple, non-composit wall with 1m length 3m height and 3cm thickness placed in the origo.Body vertex idx: 1 [1.0 0.3 0.0]
These are all the vertices of the body
Body vertex idx: 2 [1.0 0.0 0.0]
Body vertex idx: 3 [0.0 0.0 0.0]
Body vertex idx: 4 [0.0 0.3 0.0]
Body vertex idx: 5 [1.0 0.3 3.0]
Body vertex idx: 6 [0.0 0.3 3.0]
Body vertex idx: 7 [1.0 0.0 3.0]
Body vertex idx: 8 [0.0 0.0 3.0]
These are all the edges of the body
Body edge nr.:1 between vertices 1 - 2
Body edge nr.:1 between [1.0 0.3 0.0]-[1.0 0.0 0.0]
Body edge nr.:1 related to polygons 3 - 1
Body edge nr.:2 between vertices 2 - 3
Body edge nr.:2 between [1.0 0.0 0.0]-[0.0 0.0 0.0]
Body edge nr.:2 related to polygons 4 - 1
Body edge nr.:3 between vertices 4 - 3
Body edge nr.:3 between [0.0 0.3 0.0]-[0.0 0.0 0.0]
Body edge nr.:3 related to polygons 1 - 5
Body edge nr.:4 between vertices 1 - 4
Body edge nr.:4 between [1.0 0.3 0.0]-[0.0 0.3 0.0]
Body edge nr.:4 related to polygons 1 - 2
Body edge nr.:5 between vertices 5 - 1
Body edge nr.:5 between [1.0 0.3 3.0]-[1.0 0.3 0.0]
Body edge nr.:5 related to polygons 3 - 2
Body edge nr.:6 between vertices 6 - 4
Body edge nr.:6 between [0.0 0.3 3.0]-[0.0 0.3 0.0]
Body edge nr.:6 related to polygons 2 - 5
Body edge nr.:7 between vertices 5 - 6
Body edge nr.:7 between [1.0 0.3 3.0]-[0.0 0.3 3.0]
Body edge nr.:7 related to polygons 2 - 6
Body edge nr.:8 between vertices 7 - 5
Body edge nr.:8 between [1.0 0.0 3.0]-[1.0 0.3 3.0]
Body edge nr.:8 related to polygons 3 - 6
Body edge nr.:9 between vertices 2 - 7
Body edge nr.:9 between [1.0 0.0 0.0]-[1.0 0.0 3.0]
Body edge nr.:9 related to polygons 3 - 4
Body edge nr.:10 between vertices 7 - 8
Body edge nr.:10 between [1.0 0.0 3.0]-[0.0 0.0 3.0]
Body edge nr.:10 related to polygons 6 - 4
Body edge nr.:11 between vertices 3 - 8
Body edge nr.:11 between [0.0 0.0 0.0]-[0.0 0.0 3.0]
Body edge nr.:11 related to polygons 4 - 5
Body edge nr.:12 between vertices 8 - 6
Body edge nr.:12 between [0.0 0.0 3.0]-[0.0 0.3 3.0]
Body edge nr.:12 related to polygons 6 - 5
These are all the Polygons of the body
Edges in this [1] pgon idx:-4
Edges in this [1] pgon idx:1
Edges in this [1] pgon idx:2
Edges in this [1] pgon idx:-3
NormalVector idx: 1 [0.0 0.0 -1.0]
Edges in this [2] pgon idx:-7
Edges in this [2] pgon idx:5
Edges in this [2] pgon idx:4
Edges in this [2] pgon idx:-6
NormalVector idx: 2 [0.0 0.0 -1.0]
Edges in this [3] pgon idx:-1
Edges in this [3] pgon idx:-5
Edges in this [3] pgon idx:-8
Edges in this [3] pgon idx:-9
NormalVector idx: 3 [0.0 0.0 1.0]
Edges in this [4] pgon idx:-2
Edges in this [4] pgon idx:9
Edges in this [4] pgon idx:10
Edges in this [4] pgon idx:-11
NormalVector idx: 4 [0.0 -1.0 0.0]
Edges in this [5] pgon idx:6
Edges in this [5] pgon idx:3
Edges in this [5] pgon idx:11
Edges in this [5] pgon idx:12
NormalVector idx: 5 [-1.0 0.0 0.0]
Edges in this [6] pgon idx:-10
Edges in this [6] pgon idx:8
Edges in this [6] pgon idx:7
Edges in this [6] pgon idx:-12
NormalVector idx: 6 [-1.0 0.0 0.0]
Here is an explanatory sketch:
2020-08-17 05:48 PM
2020-08-18 05:58 PM
2020-08-18 08:04 PM
