VS17 : Attached to Archicad.exe and debugging is not working - SOLVED
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
‎2021-06-09
09:06 AM
‎2021-09-14
09:35 AM
Noemi Balogh
‎2021-06-09
09:06 AM
Hello! *Edit* I am using Archicad 24.
I have a problem debugging an add-on. The add-on works in Archicad very well after I followed every step to setup the environment required to develop Addons.
I attached Visual Studio 2017 to the Archciad.exe as it was mentioned in the documentation but the
Before you will redirect me to any other post I've already read this posthttps://archicad-talk.graphisoft.com/viewtopic.php?f=23&t=72673
I have my solution configured to "Native code", I enabled the "Attach to process" in the debug options.
Basically I made every step the documentation mentioned.
These are my #includes in the code
Thank you!
DBPrintf("some string");still not gives any output in the Output window.
#include "APIEnvir.h" #include "ACAPinc.h" #include "ResourceIds.hpp" #include "DGModule.hpp" #include "APIdefs_Goodies.h" #include "GSRoot.hpp" #include <iostream>Please help me amazing developers from Graphisoft
Thank you!
Labels:
- Labels:
Add-On (C++)
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2021-06-10 08:38 AM
‎2021-06-10
08:38 AM
So i think I found the answer!
2>ACAP_STATD.lib(ACAPlib.obj) : warning LNK4099: PDB 'API_c.pdb' was not found with 'ACAP_STATD.lib(ACAPlib.obj)' or at 'D:\TEMP\ARCHICAD ADDON TEMPLATE\archicad-addon-cmake-master_backup\Build\Debug\API_c.pdb'; linking objectas if no debug info
2>AddOn.vcxproj -> D:\TEMP\ARCHICAD ADDON TEMPLATE\archicad-addon-cmake-master_backup\Build\Debug\ExampleAddOn.apx
2>Done building project "AddOn.vcxproj".
3>------ Skipped Build: Project: ALL_BUILD, Configuration: Debug x64 ------
3>Project not selected to build for this solution configuration
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2021-06-10 10:00 PM
‎2021-06-10
10:00 PM
This was not the answer. This is an error which can be ignored as some said on this forum. I updated archicad and it started to work just like that. I still got some errors from vs2017 about not found .pdb files related to Archicad’s main dll files.
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2021-06-15 09:55 AM
‎2021-06-15
09:55 AM
Viktor Kovacs mentioned in another post that in the Debugging menu -> Command should be set to Archicad.exe file location. Everything works now.
