LVirone Greisch
What API methods or Struct handle Cut Operation of Opening Elements
To handle Boolean Operations we have ACAPI_Element_SolidLink methods.
But I don't know how "cut" Elements like Opening Elements do, can someone help ?
Thanks
Virone Lorenzo
3 Replies 3
Could you describe the context in a bit more detail? Do you want to make an arbitrary hole in an element? Or are you cutting is to fit some other element?
Ralph Wessel BArch
Central Innovation
LVirone Greisch
I created an opening (using the opening tool, the Element is a API_OpeningType). This Element cut it's owner, but it's possible to cut more Element using the same user button you use to add Boolean operations, but instead it's a "cut" operation which is not part of ACAPI_Element_SolidLink.
Image of the Opening with the button :
Virone Lorenzo
LVirone Greisch
Any news on this ?
In Archicad 23 API news I found this "Currently adding new elements to an opening is not available via API" and I hope it's available in API of Archicad 28.
https://archicadapi.graphisoft.com/new-api-features-in-archicad-23
Virone Lorenzo
