ā2025-05-16 09:48 AM - edited ā2025-06-13 12:34 PM
To handle Boolean Operations we have ACAPI_Element_SolidLink methods.
But I don't know how "cut" Elements like Opening Elements do, can someone help ?
Thanks
ā2025-05-16 12:08 PM
Could you describe the context in a bit more detail? Do you want to make an arbitrary hole in an element? Or are you cutting is to fit some other element?
ā2025-05-16
12:17 PM
ā2025-05-16
11:53 PM
I created an opening (using the opening tool, the Element is a API_OpeningType). This Element cut it's owner, but it's possible to cut more Element using the same user button you use to add Boolean operations, but instead it's a "cut" operation which is not part of ACAPI_Element_SolidLink.
Image of the Opening with the button :
ā2025-06-13 12:33 PM - edited ā2025-06-13 01:50 PM
Any news on this ?
In Archicad 23 API news I found this "Currently adding new elements to an opening is not available via API" and I hope it's available in API of Archicad 28.
https://archicadapi.graphisoft.com/new-api-features-in-archicad-23
