Archicad C++ API
Why can't only ACAPI_LibPart_GetSect_ParamDef work?
LeeJaeYoung
Libpart_test
static void Do_CreateLibraryPart (void)
err = ACAPI_LibPart_GetSect_ParamDef (&libPart, addPars, &aa, &bb, nullptr, &sectionHdl);
GS::UniString passStr1;
passStr1 = "12341234";
err = ACAPI_LibPart_GetSect_ParamDef (&libPart, addPars, &aa, &bb, nullptr, &sectionHdl, &passStr1);
what's wrong?
It's really hard because it seems like it can be done, but it can't be done. ^^
If you can't create a new file with your password, please say no.
AC27 on window 11
5 REPLIES 5
sayon3d
Hi Lee,
I´m not familiar with scripting but take a look at this.
https://gdl.graphisoft.com/reference-guide/expressions
Maybe there are some restrictions and rules to it.
Good Luck.
I don't understand what you mean.
Can I ask for a little clarification?
AC27 on window 11
Can you explain us first, what that script does, or what do you want to create, in Words?
I am studying libpart_test among API samples.
The manual says that you can use passwords in functions.
If you change the code of static void Do_CreateLibraryPart (void) as above,
It is not created at all.
That's why I asked you a question.
The remaining two functions with passwords work.
AC27 on window 11
LeeJaeYoung
It seems to me that I am misjudged in my greed.
What I want to hear is that it is not possible to set a password with the API, but since I do not hear an answer, it seems to be an illusion that this is the correct answer.
The password used here seems to be used when bringing something with a password, not setting. (Like the other two..)
AC27 on window 11
