‎2023-06-11 05:24 PM - edited ‎2023-06-11 06:03 PM
‎2023-06-11 05:40 PM
Hi Lee,
I´m not familiar with scripting but take a look at this.
https://gdl.graphisoft.com/reference-guide/expressions
Maybe there are some restrictions and rules to it.
Good Luck.
‎2023-06-11 05:45 PM
I don't understand what you mean.
Can I ask for a little clarification?
‎2023-06-11 06:11 PM
Can you explain us first, what that script does, or what do you want to create, in Words?
‎2023-06-11 06:17 PM
I am studying libpart_test among API samples.
The manual says that you can use passwords in functions.
If you change the code of static void Do_CreateLibraryPart (void) as above,
It is not created at all.
That's why I asked you a question.
The remaining two functions with passwords work.
‎2023-06-12 01:25 AM
It seems to me that I am misjudged in my greed.
What I want to hear is that it is not possible to set a password with the API, but since I do not hear an answer, it seems to be an illusion that this is the correct answer.
The password used here seems to be used when bringing something with a password, not setting. (Like the other two..)
