Archicad C++ API
Why is the UV obtained through ACAPI_ModelAccess_GetTextureCoord API different from ArchiCAD?
sxs
Hi,everyone:
 In ArchiCad:
In my Render System:
It is obvious that the size of the texture is inconsistent(Ignore color).
I'm pretty sure the exported texture file is fine, so I think it's a UV issue.
					//texture
					API_TexCoordPars	pars = { 0 };
					pars.elemIdx = elemIdx;
					pars.bodyIdx = bodyIdx;
					pars.pgonIndex = j;
					pars.surfacePoint.x = backCo.x;
					pars.surfacePoint.y = backCo.y;
					pars.surfacePoint.z = backCo.z;
					err = ACAPI_ModelAccess_GetTextureCoord(&pars, &resultUV);
					if (err == NoError)
						uv.push_back({ resultUV.u, resultUV.v });
sxs
if (err == NoError)
						uv.push_back({ resultUV.u / xSize, resultUV.v / ySize });
It seems that the following actions need to be taken.But the xSize/ySize I get can not produce the correct effect.
sxs
if (err == NoError)
@sxs wrote:
if (err == NoError)
It can work.
The reason is that the texture is missing.
