Correction. WriteReport_Alert (which calls ACAPI_WriteReport with 'true' as the second param) displays both the dialog as well as makes the report entry for me (Mac).
WriteReport, which is supposed to make an entry in the session report, but NOT bring up a dialog (calls ACAPI_WriteReport with false as 2nd arg), enters nothing into the report.
One of us will have to test ACAPI_WriteReport directly to see if the issue is the Mac API, or the formatting of the buffer by the code in the example files WriteReport function...
Yes... I just called ACAPI_WriteReport directly, and the text was printed into the session report as it should. So, something seems amiss with the WriteReport routine in the APICommon.c file.
One of the forum moderators
AC 28 USA and earlier • macOS Sonoma 14.7.1, MacBook Pro M2 Max 12CPU/30GPU cores, 32GB
