Archicad C++ API
SOLVED!
enable / disable menu items with function
Martin Walter
I would like to enable/disable menu items by a function.
some examples where I need this:
1: only if there is a window or door selected a menu item shall be enabled
2: only if username and password are filled in my settings dialog the other menu items shall be enabled
How is this possible?
AC22-27, Windows 11, i7-1355U, 32GB RAM, 2TB SSD
1 ACCEPTED SOLUTION
Solution
Martin Walter
Finally I solved it by returning APIAddon_Preload from CheckEnvironment().
Then Initialize() is called at the Start of Archicad.
4 REPLIES 4
The status of menu items can be managed using ACAPI_Interface with APIIo_SetMenuItemFlagsID.
Ralph Wessel BArch
Central Innovation
Martin Walter
The function works, but it's not clear when to call it.
I want some menu items to be enabled/disabled from program start.
Solution
Martin Walter
Why did you return APIAddon_Preload from CheckEnvironment() instead of APIAddon_Normal?
