Archicad C++ API
mapId is reset to 0 (API_UndefinedMap) [SOLVED TEMPORARILY]
ReignBough
I don't know if this is a bug or intentional. Here is the code:
navi_map_id = API_PublisherSets;
set.mapId = navi_map_id;
set.wantsExtraInfo = (navi_map_id == API_PublisherSets) ? 1 : 0;
DBPrintf("1 - set.mapId: %d (%d)", set.mapId, navi_map_id);
err = ACAPI_Environment(APIEnv_GetNavigatorSetID, &set, &i);
DBPrintf("2 - set.mapId: %d (%d)", set.mapId, navi_map_id);
And here is the output:
1 - set.mapId: 5 (5)
2 - set.mapId: 0 (5)
As you can see, the value of set.mapId was reset to 0.
~ReignBough~
ARCHICAD 26 INT (from AC18)
Windows 11 Pro, AMD Ryzen 7, 3.20GHz, 32.0GB RAM, 64-bit OS
Tibor Lorantfy
The set is a local object, so if you change it's mapId it won't affect the application's navigator set.
That's why it gives you the unmodified mapId if you get the navigator set again with APIEnv_GetNavigatorSetID.
Why do you want to change the mapId?
Best Regards,
Tibor
ReignBough
If my understanding is correct, ACAPI_Environment(APIEnv_GetNavigatorSetID) will retrieve the information of a navigator set determined by the mapId. But if the returned information gives me a value of 0 in the mapId (which is API_UndefinedMap) after I called the function, this means that the navigator set that was returned to me is undefined (or unknown).
I am not changing the mapId. I just want to check and/or use the value of the mapId after the call. But it became 0.
~ReignBough~
Tibor Lorantfy
I've checked that, and you're right.
ACAPI_Environment(APIEnv_GetNavigatorSetID,…) function retrieves only the following informations of the navigator:
name, guid, rootGuid and path if it's exists.
Unfortunately it always sets the mapId property to 0. But the mapId is an input parameter here, so you should know it before calling the function.
Anyway, we will fix this bug in the next API version, the output's mapId will be the same as the input's mapId of course. Thanks for pointing out this issue!
Regards,
Tibor Lorántfy
