2004-06-15 07:45 PM - last edited on 2023-08-07 12:21 PM by Doreena Deng
Looking at the PDF link that you posted, I think you're in for some "fun", Tor Jørgen! Welcome!I'm glad for the welcome, but I worry that maybe I'm in over my head - I guess thats where the fun starts...
2004-07-02 01:27 PM
Tor wrote:Yes, you've got it right
Ralph wrote:All the files should be set to compile for debugging (in the debug column in the main project window).I'm not quite shure what you mean, but I've clicked the little dot under the little green bug in the main project window.
Tor wrote:Double check that ArchiCAD is specified as the Host Application in the project Runtime Settings. Also, have a look at Debugger Settings - the option to 'Stop on application launch' should be off.
Now I can start ArchiCAD by clicking Run, but when I click Debug it says 'loading debugging data for target "add-on debug', but nothing happens...
2007-11-07 01:57 AM
stefan wrote:
In Visual Studio 6.0 you can create a new ArchiCAD Add-on with the provided wizard.
2007-11-07 03:43 AM
bamboos wrote:During the installation of the devkit, it asks if you want to install the wizard. It won't install to VS 2005, only to VS 2003 AFAIK. All it does is give you a stripped down add-on with no functionality to use as a starting point. Similarly, you can just take the simplest of the example files and modify it...
I have API Development Kit 11.21 installed, ArchiCAD 11 installed, Visual Studio 6.0 installed and Visual Studio 2005 also installed... Where is wizard You are talking about? I'm able to compile examples, but creating new project is out of my range:/
Please help.
2007-11-07 10:31 AM
2007-11-07 05:04 PM
2007-11-07 05:13 PM
2007-11-07 05:19 PM
2007-11-07 05:21 PM
2007-11-07 05:23 PM
2007-11-07 05:28 PM
