Archicad C++ API
newbie question
Hi all,
So, for debug my add-on, I use ACAPI_WriteReport() function for display a const char*. But I would like to display a int and cast doesn't works .
I search for an other function but no result...
Did you have an idea for display a int ?
PS : Pointbreaks does'nt works too...
Ralph Wessel
Mentor
Are you not able to use the debugger, i.e. set breakpoints, step through the code, and examine variables directly? Which compiler/IDE are you using?
Ralph Wessel BArch
Active Thread Ltd
Akos Somorjai
Hi all,
In C, you cannot cast an int to a const char*.
Do something like this:
char message[256];
int val = 27;
sprintf (message, "Integer value: %d", val);
ACAPI_WriteReport (message);
I'd recommend looking at a basic C/C++ tutorial before diving into the API.
Best, Akos
