Archicad C++ API
whether palette dialog can add other item types dynamically?
Hi.
I create a palette dialog class.
And I want to add some items dynamically. eg. button.
Are there some methods?
Thanks.
Akos Somorjai
Please find below some sample code (it uses a Dialog, not a Palette).
Best, Akos
7 REPLIES 7
Akos Somorjai
DG::Button has such a constructor is you do not want to load it from a resource file (see DGButton.hpp):
Button (const Panel& panel, const Rect& rect, ButtonType type = Normal, FrameType frameType = Frame);
Pass the palette as the first param, and the desired rect in the second.
Best, Akos
Best, Akos
Thanks.
Besides, I want to add a tabpage.TabPage constructor need TabControl. How can add it?
Thanks.
Hi.
Besides, I want to add a tabpage in the palette dialog.
How can add it?
Thanks.
Akos Somorjai
Best, Akos
Best, Akos
Thanks.
I can't find 'GS::Owner' and 'GS::NewOwned' in your code.
Whether I need to import other header files?
Akos Somorjai
Please include "Owner.hpp"; it is in the GSRoot module.
Best, Akos
Best, Akos
Thank you very much.
Now I can add 'TabPage' dynamically.
