‎2021-06-16
03:49 PM
‎2021-09-14
09:34 AM
Noemi Balogh
JSON::JDOMParser jParser;
JSON::ValueRef parsed = jParser.Parse(clientConnection.BeginReceive(response));
JSON::ObjectValueRef obj = GS::DynamicCast<JSON::ObjectValue>(parsed);
GS::UIndex idx = 0;
GS::UniString name = obj->GetName(idx);//This gets me the value "results" as it should
bool isObj = obj->IsObject();//true
JSON::ValueRef resultsRef = obj->Get("results");//If I DBPrintf this it ouputs "Array"
I don't fully understand how to "navigate" or "read" the parsed Object. I didn't found any documentation about the JSON Parser below
JSON::JDOMParserCan you please help me with some ideas how to traverse this JSON object?
‎2021-06-17 03:35 PM
using namespace HTTP::Client;
using namespace HTTP::MessageHeader;
using namespace GS::IBinaryChannelUtilities;
IO::URI::URI connectionUrl("http://geoportal.ancpi.ro/geoprocessing/rest/services/LOOKUP/UATLookup/GPServer/FastSelect/execute?f=json&Expression=WORKSPACEID=10");
ClientConnection clientConnection(connectionUrl);
clientConnection.Connect();
Request getRequest(Method::Get, connectionUrl);
getRequest.GetRequestHeaderFieldCollection().Add(HeaderFieldName::UserAgent,
"Mozilla/5.0 (X11; Linux x86_64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/77.0.3865.90 Safari/537.36");
clientConnection.Send(getRequest);
Response response;
//Parse the top object of the JSON File
//Get the array named results into arrValRef
GS::UniString atName = "results";
JSON::ArrayValueRef arrValRef;
obj->GetMandatoryMember(atName, arrValRef);
//Get the first and single item of the array
JSON::ValueRef first = arrValRef->Get(0);
//Parse it again into an ObjectValueRef
JSON::ObjectValueRef resultsObj = GS::DynamicCast<JSON::ObjectValue>(first);
//debug so I can be sure what it is
DBPrintf("Size of reultsObj is %u\n", resultsObj->GetSize());
DBPrintf("Type of resultsObj[2] is %s\n", resultsObj->GetName(2).ToCStr().Get());
//Get the third element from results array : "value" this is an object
JSON::ValueRef valuesRef = resultsObj->Get(2);
//Parse it into a ObjectvalueRef
JSON::ObjectValueRef valuesObj = GS::DynamicCast<JSON::ObjectValue>(valuesRef);
//Get the array I wanted finally, the features array containing information about cities
JSON::ArrayValueRef fieldsArray;
valuesObj->GetMandatoryMember("features", fieldsArray);
//Iterate trough the "features" array
for (unsigned int i = 0; i <= fieldsArray->GetSize(); i++) {
//Debug to be sure that the correct one is selected
DBPrintf("Working %u times\n", i);
/*GS::IChannelX channel(clientConnection.BeginReceive(response), GS::GetNetworkByteOrderIProtocolX());
DBPrintf("HTTP %u\n", response.GetStatusCode());
DBPrintf("Received data: \n");
GS::UniString body = ReadUniStringAsUTF8(channel, StringSerializationType::NotTerminated);
GS::Array<GS::UniString> lines;
body.Split("\n", GS::UniString::KeepEmptyParts, &lines);
for (GS::UniString& line : lines) {
DBPrintf("%s\n", line.ToCStr(0, MaxUSize, GSCharCode::CC_Legacy).Get());
DBPrintf("Read %u characters, %u lines \n", body.GetLength(), lines.GetSize());*/
clientConnection.FinishReceive();
clientConnection.Close(false);
‎2021-06-17 03:50 PM
"attributes": {
"OID": 2,
"ADMINISTRATIVEUNITID": 1213,
"UAT": "Aiud"
The JDOMParser gave me some inconsistent results as shown bellow.Type of fieldsArray[0] is: Array Type of fieldsArray[1] is: String Type of fieldsArray[2] is: Unknown Type of fieldsArray[3] is: Bool Type of fieldsArray[4] is: Unknown Type of fieldsArray[5] is: Unknown Type of fieldsArray[6] is: String Type of fieldsArray[7] is: Unknown Type of fieldsArray[8] is: Unknown Type of fieldsArray[9] is: Unknown Type of fieldsArray[10] is: Null Type of fieldsArray[11] is: Unknown Type of fieldsArray[12] is: Bool Type of fieldsArray[13] is: Unknown Type of fieldsArray[14] is: Unknown Type of fieldsArray[15] is: Null Type of fieldsArray[16] is: Unknown Type of fieldsArray[17] is: Unknown Type of fieldsArray[18] is: Object Type of fieldsArray[19] is: Array Type of fieldsArray[20] is: Unknown Type of fieldsArray[21] is: Null Type of fieldsArray[22] is: Object Type of fieldsArray[23] is: Unknown Type of fieldsArray[24] is: Bool Type of fieldsArray[25] is: Unknown Type of fieldsArray[26] is: Unknown Type of fieldsArray[27] is: Bool Type of fieldsArray[28] is: Unknown Type of fieldsArray[29] is: Unknown Type of fieldsArray[30] is: Bool Type of fieldsArray[31] is: Unknown Type of fieldsArray[32] is: Unknown Type of fieldsArray[33] is: Bool Type of fieldsArray[34] is: Unknown Type of fieldsArray[35] is: Unknown Type of fieldsArray[36] is: Bool Type of fieldsArray[37] is: Unknown Type of fieldsArray[38] is: Unknown Type of fieldsArray[39] is: Null Type of fieldsArray[40] is: Unknown Type of fieldsArray[41] is: Unknown Type of fieldsArray[42] is: Object Type of fieldsArray[43] is: Unknown Type of fieldsArray[44] is: Unknown Type of fieldsArray[45] is: Null Type of fieldsArray[46] is: Null Type of fieldsArray[47] is: Unknown Type of fieldsArray[48] is: Bool Type of fieldsArray[49] is: Unknown Type of fieldsArray[50] is: Unknown Type of fieldsArray[51] is: Unknown Type of fieldsArray[52] is: Unknown Type of fieldsArray[53] is: Unknown Type of fieldsArray[54] is: Bool Type of fieldsArray[55] is: Array Type of fieldsArray[56] is: Unknown Type of fieldsArray[57] is: Bool Type of fieldsArray[58] is: Object Type of fieldsArray[59] is: Unknown Type of fieldsArray[60] is: Unknown Type of fieldsArray[61] is: Unknown Type of fieldsArray[62] is: Unknown Type of fieldsArray[63] is: Unknown Type of fieldsArray[64] is: Unknown Type of fieldsArray[65] is: Unknown Type of fieldsArray[66] is: Object Type of fieldsArray[67] is: Unknown Type of fieldsArray[68] is: Unknown Type of fieldsArray[69] is: Unknown Type of fieldsArray[70] is: Unknown Type of fieldsArray[71] is: Unknown Type of fieldsArray[72] is: String Type of fieldsArray[73] is: Unknown Type of fieldsArray[74] is: Unknown Type of fieldsArray[75] is: Unknown Type of fieldsArray[76] is: Unknown Type of fieldsArray[77] is: Unknown Type of fieldsArray[78] is: Number
‎2021-06-17 04:28 PM
