Tibor Lorantfy
Python API Experiment is Open
The testing of the current Python API Experimental Version officially begins with 200 beta testing spots available.
Python API development is still in experimental phase, we are investigating the possible solutions. We'll make our choice depending on the real user requirements.
If you are an ARCHICAD user, can write Python scripts, wish to improve the software, and can communicate in English, then this is your chance!
Join Python API experiment now!
https://beta.graphisoft.com
11 Replies 11
Great! Applied
Great! Hope the 200 spots are not gone allready.
The Links do not work 😕 Are the spots all gone?
I logged in all the way to the "Join Python API experiment now!" link ... which I didn't click on so that I would not use up one of the 200 test spots. Are you saying that THAT link does not work for you?
https://beta.graphisoft.com/
This one is not working, I mean it does not open any page.
Works fine for me. Your ISP or DNS might be restricting your access to the site? Have you tried from a different device / browser / internet connection ?
The same problem was with the Graphisoft API site, which also did not open. Browsers have nothing to do with (win7 and IE, firefox, Google). Try through the Tor browser - this will solve everything. "Strange" sites.
Tried with 3 browsers and 2 different connections. The website opened only on the phone with the same internet connection. Seems the problem is with the laptop device. Anyhow, I have already registered and transferred all the necessary files from the phone to the laptop. However, it's gonna be hard to read through the beta forum on the phone all the time . The betaforum website doesn't open either. It redirects to beta.graphisoft.com where it stops. I checked the loaded html content and as it seems almost nothing is being loaded.
Nader Belal
Mentor
Try Opera Browser, it worked with me
