Archicad Python API
About automating tasks in Archicad using the Python API.
Python Upgrade
poco2013
Mentor
Graphisoft just release a new version of the Python APi -- version 24.3022. The upgrade fixes a compatibility problem with Python 3.9. However, the documentation was not upgraded. Am I correct in assuming that no new commands were added? There is no documentation after version 24.3004
Also, I should have noticed this earlier, but it appears that the command line was removed from the Python palette from the experimental version.
This makes it difficult to peruse the python environment and perhaps determine the commands and help info there?
Can we get the command line back?
Gerry
runxel
Legend
Baffled me big as well.
Especially since the big words were "we will deliver a big upgrade in the api with the first update of AC 24"... – well here it is but again nothing else than broken promises.
Lucas Becker | AC 27 on Mac | Author of Runxel's Archicad Wiki | Editor at SelfGDL | Developer of the GDL plugin for Sublime Text | My List of AC shortcomings & bugs | I Will Piledrive You If You Mention AI Again |
Have you guys seen this:
https://archicad-talk.graphisoft.com/viewtopic.php?f=10&t=71183
This means the final version of the Update is coming soon, so we will soon see if it includes any updates to Python.
runxel
Legend
Yes, I've seen it, but I can't remember a single time were the preview was significantly different from the final one.
Also I remember the last times well! Polygonal openings or ramps anyone?
So I don't have too much faith left, sadly.
