Friday
- last edited
Saturday
Hello. I am currently working on a script that extracts Archicad IDs and assigns the composite names of walls, slabs, etc. I know there is a topic about this but for C++. I can't figure it out. My best attempt can be seen below.
rep from Python palette
Spouštění skriptu prepis podláh 2.py
Slab ID: p02, Composite: Unknown composite
Slab ID: p03, Composite: Unknown composite
Slab ID: p04, Composite: Unknown composite
Slab ID: p01, Composite: Unknown composite
=== Proces dokončen ==
Script
from archicad import ACConnection
# Connecting to Archicad
conn = ACConnection.connect()
if not conn:
raise Exception("Failed to connect to Archicad")
# Shortened references
acc = conn.commands
acu = conn.utilities
act = conn.types
# Getting the ID of the property 'General_ElementID'
property_id = acu.GetBuiltInPropertyId('General_ElementID')
# Getting all slabs
elements = acc.GetElementsByType('Slab')
# Getting all composites (sandwich structures)
composite_ids = [comp.attributeId for comp in acc.GetAttributesByType('Composite')]
composite_details = acc.GetCompositeAttributes(composite_ids)
# Mapping: composite ID -> composite name
composites = {comp.compositeAttribute.attributeId.guid: comp.compositeAttribute.name for comp in composite_details if comp.compositeAttribute}
# Getting the Archicad ID and composite name (sandwich structure) using the property 'General_ElementID'
def print_slab_ids_and_composites():
property_values = acc.GetPropertyValuesOfElements(elements, [property_id])
for element, value_list in zip(elements, property_values):
archicad_id = None
for value in value_list.propertyValues:
archicad_id = value.propertyValue.value
# Attempt to get the composite ID through classifications or parameters
try:
composite_id = element.elementAttributes[0].attributeId.guid # Confirm or adjust this method if available
except AttributeError:
composite_id = None
# Getting the composite name
composite_name = composites.get(composite_id, "Unknown composite")
# Printing the slab ID and composite name
print(f"Slab ID: {archicad_id}, Composite: {composite_name}")
