HTu
Error found in the Override_Test API example
Hello everyone,
I need to create an API to set the Fill Background Pen Override = zero (transparent)
So I looked up the Override_Test API example and discovered the error in the "CreateTransparentWDOverrideRule" function. It returned APIERR_BADPARS when activated the "Set Perspective View's Override Combination" function of the example.
I have narrowed down the source of the issue. It is from the following settings:
// Override fill background pen to 0 (transparent)
rule.style.fillBackgroundPenOverride = static_cast<short> (0);
Any suggestion to overcome this error would be greatly appreciated!
Regards,
Hoa
0 Replies 0
