on
2021-07-07
12:00 PM
- edited on
2024-11-13
08:54 PM
Roland Szabo
BIMx iOS or Android application must be installed to make hyperlinks work. To use such URLs to open a model or 3D element(s), the Hyper-model must be imported to BIMx on the mobile device.
Download and import a BIMx Hyper-model to the mobile app with one tap from any web-enabled public or private cloud storage. The prerequisite of automated download is that the .bimx file must be available on a basic http or https URL without any further query parameter.
Use the below-described model import URL instead of sharing a model's BIMx Model Transfer website URL (e.g. this simple link), ask your client to open it, and import the model to the app with BIMx Model Transfer's Download button.
The easier way is to copy the model import URL with a long tap on BIMx Model Transfer's Download button on a mobile device, e.g. Chrome on iPad:
Copied URL:
Same URL inserted: Import to BIMx Mobile.
Tapping the URL immediately starts importing the model to BIMx:
You can also set up the link manually (recommended when the model is on your own storage):
By parameters:
bimxapplication://bimx-storage.graphisoft.com/Download/dff02b7d-af0e-4a51-9da3-b3c49dd140c0?
name=Two-wall%20example%20model&
folderId=586117&
type=HyperModel&
protocol=https&
trsite=1
You can define a model open URL that will work if the model is already imported.
Template:
bimxapplication://showHypermodelContents?hypermodel=hypermodel_name
You can create hyperlinks directly to 3D elements. This allows you to simplify getting into context. No need to search the Hyper-model in BIMx, open a 3D model, and navigate to the proper camera position.
Same link inserted: Open wall element in BIMx. Result:
The copied hyperlinks work the same way on iOS, iPadOS and Android.
Note: Hyperlinks for quick-checking can be also generated in the Web application on BIMx Model Transfer (with 24h expiration, see Help). However, there is no transition between browser and mobile apps.
The hypermodel_name part needs to be replaced with the URL encoded Hyper-model name.
The third part contains the Unique_ID of the element(s) that you want to access with the hyperlink. The hyperlink can contain multiple Unique_IDs, so BIMx will open the 3D model with all listed elements, selected in green color.These IDs can be obtained in Archicad by listing the Unique ID field in an Interactive Element Schedule:
In addition to this automatic hyperlink between 2D and 3D, you can add any BIMx hyperlinks to schedules as custom texts. E.g., element hyperlink with camera position (copied from BIMx) or without it (created manually):
is it possible to do this also with the BIMx desktop version?
Unfortunately it is not possible to access model elements with hyperlinks in BIMx Desktop Viewer. However it would be a nice improvement, we will take it into consideration in future developments.
Kind regards,
Norbert Kucsma
Technical Support Engineer, Technical Support Team
GRAPHISOFT SE, Budapest
this feature would definitely be very useful!
thanks a lot
